Hey felix,
See these inline scripts in the Resources:
This first one will allow you to midify the js file to set the size of the image you want to be captured from the active viewport.. Set at 2560x2560, you can change this resolution to anything you want/need. It then puts that image on the windows clipboard for pasting where needed.
an awesome program thats free is gadwin www.gadwin.com
hit printscreen and it will save whole screen or drag a selection and save as a jpg or send to printer directly
and easy to use
cheers
shayne
Hi Shane,
There is an advantage to using the script from within MoI to do the model capture though.. It is capturing the viewport data and is monitor independant.. A screen grab will be at a limited resolution. The script will only be limited by your video card.
