After a Slice
All  1-3  4-12
4339.4 In reply to 4339.3
> Does it possible for the perfection to enter another angle
> at the start? (negative or not?)
You can make it use a different angle by editing the script in a text editor - at line 30 of the file you'll see this code:
// Angle to rotate by.
factory.setInput( 2, 90.0 );
The value 90.0 there is the rotation angle value that will be used. So if it's not going in the direction that you want you can change that to -90.0 instead (you'll need to restart MoI if you've run the command once in the current session).
> PS does the "Centroid" of the object is the "centroid" of the Edit Frame?
Yup, it should be the same I think.
4339.5 In reply to 4339.4
So all is perfect!
Bravo !
If I put 15 °, except the fact that i must click 6 times for have 90° :)
does this increase anormally the memory size used if i have a lot of objects
or it's peanuts for the history of the undo redo with this command?
4339.6 In reply to 4339.5
Pilou, you could also create 4 or so js files with different sized values, and just add the value to the end of the filename... So a 90, a 45, a 30 and a 10 or something...
I was also trying to figure out how to create an htm file for the command to draw the value from an angle field... I was trying to refer to another command to see how it was done, like in the rotate command, but it's a more complex command and I cant decypher it at the moment.. Trying to find "which of the current MoI commands is the simplist" with regard to a js file retreiving an input value from the UI?
4339.7 In reply to 4339.6
Cool trick ;)
About the memory size of this sort of command if I play with it at different times with numerous objects
that not produce an huge memory used for the undo redo?
4339.8 In reply to 4339.7
Hi Pilou, well each time you run the command it will make a record of the previous objects in the undo stack.
However, those records are internally compressed (like zipped) to reduce their memory consumption, and also once you exceed a certain amount of memory used by the undo stack (set in moi.ini in the [Undo] section with the MaxMemorySizeMB= setting, default is 20 MB) the older undo records will automatically be purged to free up memory.
It will keep a minimum number of undo steps though before purging any of them, the default is a minimum of 10 steps.
So it's not likely to create a problem for you unless you have such a highly detailed model that it fills up a huge amount of memory just with the minimum 10 undo steps.
4339.9 In reply to 4339.6
Hi Burr & Pilou - here is a version that puts up some UI along with it where you can enter in the rotation value.
Copy both attached files to the \commands folder, the .js file is updated from the one in the previous post also.
4339.10 In reply to 4339.9
Thank you Michael,
I appreciate it.
4339.11 In reply to 4339.9
Perfect! Works like a charme!
We must now just right click twice ;) but enter angle is possible!
That is a very tiny thing compare to the possibility! ;)
Bravo again for the reactivity!
EDITED: 19 Jun 2011 by PILOU
a little tut video ;) (Sweep 2Rails, Explode Move, RotateObjects )
http://moiscript.weebly.com/pivoter-des-objets.html sorry always in French but visual :)
EDITED: 20 Jun 2011 by PILOU
Show messages: All  1-3  4-12
