Distance command
All  1-2  3-5
4331.3 In reply to 4331.2
Michael,
I've join the custom distance file as requested. But beside the precision thing I like the temp line that's created more then I dislike having to save the file, so I suggest not doing anything to that part.
While you check this out, I'll check the reference you gave, may that will do just fine. Give me a few minutes to check it out.
Felix
edit: It seems I have an old version of the command, the htm file doesn't use "class" or "style" for the "TD's"
edit #2 I've modified the htm file to show fixed 4 decimal place and I can live with that but I still think it would be nicer if the command would reflect the option setting automatically. (Included new htm file)
EDITED: 13 Jun 2011 by FELIX
4331.4 In reply to 4331.3
Hi Felix - here's a version that should use the settings from options, both for "Decimal display", as well as "Show trailing zeros".
4331.5 In reply to 4331.4
Michael,
it works just fine now.
Felix
Show messages: All  1-2  3-5
