Array on 2 curves?
All  1  2-7
4324.2 In reply to 4324.1
Hi Pilou, are you possibly missing an image attachment there?
It sounds like you may want a function called "Extract Isoparms" - that's a NURBS mechanism where after creating a surface you can extract out different curves from it in either the U or V directions. That could go on the wishlist for v3.
4324.3 In reply to 4324.2
< are you possibly missing an image attachment there?
yes done ;)
And sure that will be a cool feature :)
4324.4 In reply to 4324.3
Hi Pilou, the images don't seem to be showing up - looks like you may be using an image host that doesn't allow the images to be embedded in other pages?
Anyway, I think that extracting isoparms would give you what you want - that would be something like actually build the sweep surface and then extract out the curve pieces that you want.
For now probably your line web method of having an additional center rail to make the web through is probably the best way.
4324.5 In reply to 4324.4
Very curious because I was seeing them!
But Now I take another one :)
Can you see it? (first post)
previouly i had used
http://www.postimage.org/
As I had seen my images in my post with the img src i believed that was no problem
http://s4.postimage.org/ty6zcspjz/array2curves.jpg
http://s4.postimage.org/ty6xp9d27/array2curves1.jpg
EDITED: 8 Jun 2011 by PILOU
4324.6 In reply to 4324.5
Hi Pilou, yup now I see the images in the first post.
4324.7 In reply to 4324.6
yes but it's because i had changed of host!
That is very mysterious!
Show messages: All  1  2-7
