MOI+eee slate Asus
All  1-16  17-19
4322.17 In reply to 4322.16
Also for Colin, Using the rotate widget from the viewport, there is an option which can help the rotation and others, under view/rotate/pan/zoom... I think the sensativity slider will help with the speed of the rotation with regard to how far you have to move your pen.. Your mesh angle helps with the viewport being sluggish due to a large heavy model, though I think you were looking for more speed with less pen movement... MoI is cool!
4322.18 In reply to 4322.15
Hi Everyone,
@Danny & Burr, Thanks for those pointers.
@Pilou, I've been told that you can use the other normal sized Wacom Pens with Buttons & this machine will recognise them.
The supplied Pen or Stylus fits into a small hole on the side of this machine, where as the normal sized Wacom Pens wouldn't.
If you're on the move & carrying this machine in a bag, then adding a normal size Wacom Pen into a pocket wouldn't be an issue.
HTH, Colin
4322.19 In reply to 4322.18
That is a good point!
Show messages: All  1-16  17-19
