AutoCAD
All  1-3  4-10
4317.4 In reply to 4317.2
Hi Danny,
> Autodesk's new free 123D will import *step from MoI and
> you could then export out *dwg.
For going that direction from MoI into AutoCAD, SAT format will also work - export SAT out from MoI and then import SAT into AutoCAD. That seems to work for both curves and solids.
I thought that this question was about the reverse direction though, about starting from AutoCAD and importing into MoI?
For that direction (AutoCAD to MoI), SAT format will work for solids, but unfortunately not for curves, it seems like AutoCAD does not export curve data to SAT format.
4317.5
Stand corrected, thanks Michael :)
4317.6 In reply to 4317.5
Hi Danny 123D is a good idea for using for DWG translation in general though.
4317.7 In reply to 4317.6
AutoCAD still does *.igs and *.iges export. I just checked in 2012 and 2D curves are exported in the *.iges format.
BTW- Is it expensive/difficult to be a TrueDWG partner? OpenDWG is OK, but seems to be a release behind and not always accurate...
4317.8 In reply to 4317.7
Hi Nick, that's great news that AutoCAD supports IGES again with the latest version!
I double checked ACAD version 2008 which I have here and it does not seem to support it, so I wonder if that's something that they added back in recently, or if possibly it is some kind of extension pack that you got along with Inventor or something like that?
Their contract had clauses in it that were not really acceptable to me, stuff like requiring the app to be submitted to Autodesk for approval something like a month before releasing it.
For me the weird thing about OpenDWG is that their "commercial" license has a restriction that you can only distribute 100 copies max out of your organization. You have to go to the next step up in order to distribute it to as many people as you want. That seems kind of odd to me that the commercial level license has that restriction in it so that has made me not a really big fan of that library either.
So overall DWG is not an easy thing to dig into, right now I don't really have a plan to support it.
DXF is actually documented (for lines and arcs type stuff, not solids unfortunately) so that's more likely what I would try to support in the future at some point.
4317.9 In reply to 4317.8
"I double checked ACAD version 2008 which I have here and it does not seem to support it, so I wonder if that's something that they added back in recently, or if possibly it is some kind of extension pack that you got along with Inventor or something like that?"
IGES has been standard for as long as I remember (not an Inventor add-in). They might have axed the command [igesout] as legacy...? Anyway, it's located in the export menu now. Try the [export] command in 2008. I only have 2012 installed currently.
8 GB RAM, ATi Radeon HD 3870
4317.10 In reply to 4317.9
Hi Nick, in AutoCAD 2008 when I do the export command I only get these choices here:
Anyway, that's great if they have added it back in to the more current versions.
Show messages: All  1-3  4-10
