Having a Boolean Difference problem
All  1-8  9-10
4302.9 In reply to 4302.6
Hi David, yeah only one of those cutting curves seems to be ok - the others appear to have a small area of self-intersection in the curve.
Notice what happens here if I turn on control points and pull them around:
See that one area of the curve where it kind of pulls out differently? That's an area where there is a tiny additional segment in the curve.
If you zoom in here and find these points:
Moving that middle point down shows that it's not just a micro segment, but that it actually kind of zig-zags backwards for a tiny amount before continuing forwards - that's the kind of self-intersection that will confuse things that involve intersections:
It's hard to know how that happened without seeing some of the earlier steps in how it was created - stuff like that can happen when 2 curves are barely grazing each other and are close to being tangent to one another where they are closest to each other but not quite - that kind of "almost tangent but not quite" situation can cause little bits left over when you try to trim stuff like that with each other.
4302.10
You guys are awesome.
I see what you describe about the construction of my cutting object. I rebuilt it and it works perfectly.
Thanks for taking the time to analyse this problem. I learned alot.
Regards.
Show messages: All  1-8  9-10
