TSplines for MoI?
All  1-2  3-9
4301.3
Hello,
I didn't know it was polys in NURBS. I'd seen a sketching tech with NURBS, I guess this isn't it. The direct manipulation looks useful.
4301.4 In reply to 4301.3
Hi OSTexo, yeah T-Splines is a bridging method between polygon sub-d modeling and NURBS.
Basically T-Splines makes it possible to generate NURBS surface output from a polygon control hull.
So the workflow and type of modeling that you use for manipulating T-Splines is a polygon sub-d modeling workflow...
The way it would work in MoI would be as an additional way to create a surface, but the tricky part is that it needs a whole set of sub-d modeling tools for manipulating it which are not currently present in MoI. Creating all the tools to go along with a pretty different editing style of workflow would take a lot of work. Meanwhile there is still a lot of stuff that I want to implement just for MoI's current NURBS modeling workflow.
Wow
Looks like T-Spline is also a company.
Some heavy reading to get some vague idea of what a T-Spline is, let alone a Nurb:
http://www.tsplines.com/technicalpapers.html
http://contentdm.lib.byu.edu/ETD/image/etd1813.pdf
http://contentdm.lib.byu.edu/ETD/image/etd804.pdf
http://contentdm.lib.byu.edu/ETD/image/etd2453.pdf
4301.6 In reply to 4301.5
Hi bemfarmer, yup T-Splines is also a company that has some products based around that technology.
4301.7
http://www.youtube.com/watch?v=3RPphJxxscY
I would love to see some tools like this incorporated into MoI more than Tsplines, since Moi already has a tablet based interface and I would love to be able to sketch out curves, then loft/sweep, etc.. to build forms. But I'm sure that it is not a simple task to incorporate sketch planes and etc...
4301.8
Would you be thinking of building the toolset yourself, or integrating T-Splines in as a plugin? T-Splines have patents on the technology they use so it would be interesting to know what exactly this prevents other developers from working on.
4301.9 In reply to 4301.8
Hi Playdo,
I don't really have a specific plan either way right now, because either one of those options each involve quite a bit of work.
As a 3rd party plug-in it still requires quite a bit of support work on my part to explain to other developers how things work and to support them, answer questions, provide documentation, help debug problems, also to probably develop a more comprehensive plug-in system that would allow more directly integrated C++ plugins instead of just script code ones. That's a lot of stuff for me to attempt to do while simultaneously trying to develop more regular end-user features for MoI as well...
They license their technology as a toolkit, so that's one possible way to incorporate it.
There are also a couple of other libraries from other companies that have some kind of similar functionality for converting sub-d control cages to NURBS but without the T-juncture mechanism that is specific to T-splines.
Show messages: All  1-2  3-9
