Simlab composer 2.3
Simlab Composer 2.3 is released
http://www.simlab-soft.com/3d-products/simlab-composer-main.aspx
(exist now in German and French ;)
Integration inside Sketchup for render and Import / Export
Import 3D From Sketchup FBX, OBJ, STEP, IGES, ACIS, SolidWorks, Inventor, SolidEdge, 3D PDF, 3D XML, U3D, STL
or export formats FBX, OBJ, U3D, 3D PDF, STL and Zim for Ipad iphone Itouch
free copy of SimLab Composer 2.3 (3D PDF edition) (value of $99) for each plugin owner from SimLab (3D PDF, importers or exporters)
all what you need to do is to send an email to license@simlab-soft with information about the plugin you already purchased
and you will receive a license and instructions.
SimLab Composer can be downloaded from http://www.simlab-soft.com/3d-products/simlab-composer-trial.aspx
SimLab Composer / SketchUp integration can be downloaded from http://www.simlab-soft.com/3d-products/simlab-composer-sketchup-integration.aspx
SimLab Composer 2.3 and the integration plugin are supported of Windows and Mac
Please send any issue you face to support@simlab-soft.com
ps For the French Manual : sure but in a few days ;)
EDITED: 21 May 2011 by PILOU
4289.2 In reply to 4289.1
Cheers Pilou ;-)
4289.3 In reply to 4289.1
With the French translation done by Pilou, right Pilou?
4289.4 In reply to 4289.3
yes ;)
4289.5 In reply to 4289.4
Way to go with the translations Pilou and Ralf, I'm getting worried that Pilou has a master plan to translate the world and we eventually all start speaking French ;)
4289.6 In reply to 4289.5
Pilou is a monster!!!! I pay attn: where I see him!!
4289.7 In reply to 4289.6
Comment puis je avoir accès à la traduction depuis la version 2.3 initiale? Dois je telecharger à nouveau Composer ou existe il un patch ?
Merci Pilou pour la traduction.
4289.8
4289.9 In reply to 4289.7
:D
@ Grandpi
I suppose yes reload can works but i will ask that because there are maybe some overwriting of new files that you can have builded in path arborescence!
Your original works for example!
So wait a day please :)
4289.10 In reply to 4289.7
@Grandpi
OK the news ! ;)
The user has two options:
A- Uninstall SimLab Composer 2.3 and install the new version with French translation, this should not overwrite existing files.
or
B- Copy this file French_translation.qm
from https://www.yousendit.com/download/dkJwTXRYcHY4NVd4dnc9PQ
to C:\Users\”user name”\AppData\Roaming\SimLab\data\languages, next time SimLab Composer will detect the new language and the user can switch the interface langugage.
Je pencherais pour la 2ème solution, comme cela aucun risque! ;)
Ou alors la première mais en doublant les fichiers de travail résultants se trouvant dans les arborescences, à un autre endroit, au cas où! :)
EDITED: 22 May 2011 by PILOU
4289.11 In reply to 4289.10
impeccable !!!.
Merci Pilou.
