Hi David... There is a difference between curves and "surface edges"... To select a surface edge you need to do a "drill down" pick, which is as you describe, selecting the surface then the second pick will target that surfaces edge.. The same is for the faces of solids or joined surfaces.. Select the object then the face will become selectable.. The edges take precedence, so you may have to zoom a bit on smaller faces to be able to target them...
