Off Set
All  1  2-6
4264.2
Thats normal. If you want to reduce the control points in the new curve, you can press tab and then type "rebuild".
4264.3 In reply to 4264.2
thanks!
4264.4 In reply to 4264.1
Hi Shaun, no you're not doing anything wrong, that's just how the Offset function works - the offset function in the geometry library happens to build a quite dense result.
The whole process of doing an offset involves a kind of fitting process that marches along the curve, with NURBS curves you cannot just offset existing control points to make an actual accurate offset curve. See this previous discussion for some more information:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3838.21
And like Ed mentions, you can use the Rebuild command to simplify the complex offset result to get something more manageable for control point editing:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
Probably in the future that rebuild step will happen automatically, I just need to ensure that it maintains the same level of accuracy in the result.
4264.5 In reply to 4264.4
Hello Michael,
Would it be possible to someday add a customizable toolbar that you can add buttons for the commands that are not part of the standard UI? maybe it can be a floating tool palette? I like your clean UI, but a little personalization would be nice for frequently used command for a task i'm working on.
Jeff
4264.6 In reply to 4264.5
Hi Jeff, yes in the future I would like to add in some kind of popup toolbox that you could customize.
Show messages: All  1  2-6
