Rebuid a Curve
All  1-5  6-9
4255.6 In reply to 4255.5
Hi Jean-Paul, you mean having a preview of several choices that were set side-by-side to one another?
I guess then the problem would be, what values to use for those 5 different curves, I guess that would require some fairly elaborate UI to switch between different setting groups....
Also imagine if you have a curve that has a closed shape - it could be pretty easy for the 5 different previews to be overlapping on top of each other making for a kind of chaotic display.
4255.7 In reply to 4255.6
Okay. Thanks for entertaining my overengineering-ness. :)
4255.8 In reply to 4255.7
Just to chime in here, the rebuild command DOES preview the value you enter, before you are required to commit it.. So if you just type in a value and hit enter, then the curve will update to reflect this value, then when you see what you like, you can right clcik (or choose done) to commit the value.
4255.9 In reply to 4255.8
Hi (BurrMan )
That it's this I wanted to say
Bravo !!!
al
Show messages: All  1-5  6-9
