About Helpers lines
All  1-4  5-11
4252.5 In reply to 4252.4
Yes it's that i have found but thinking that "middle" was an omission ;)
Division Snap gives many more snaps than just a "middle" ;)
4252.6 In reply to 4252.5
It's normal for something to be omitted when it is not frequently used but still pretty easy to accomplish.
This case that you're talking about falls exactly into that category - you can get the point you want in about 1 second by creating a second construction line over top of the first one, between the first one's end and middle.
4252.7 In reply to 4252.6
< between the first one's end and middle
Yes but in this case for a "middle" that add 3 new snap points against only one with a direct method! ;)
So some difficulties to choose the good one in case of complex small aera :)
If don't using it immediatly the snap and draw other helpes for any reasons!
EDITED: 9 May 2011 by PILOU
4252.8 In reply to 4252.7
Yes, that's pretty much why the default is to not create so many snap points in the first place, such as only making reflected end points and not reflected mid points.
But the solution to the difficulty that you're talking about with having a complex small area is to zoom in so that you can more easily see the different points and make it not a small area anymore.
When you find yourself running into difficulties telling points from one another, you should zoom in - try to get in a habit of doing this sooner rather than later - I mean right at the moment that it seems that you're having some difficulty zoom in there rather than wasting too much time continuing to struggle with it at the current view.
4252.9 In reply to 4252.8
Yes sure but if you zoom you are not more capable to see if it's the good one ;)
In any case there some strategy for avoid that ;)
4252.10 In reply to 4252.9
Sorry, I don't really understand what this part means.
Maybe you are zooming in too much? That could also cause some difficulties.
Just in general if you have a small area of the screen that is complex and it is hard for you to pick the exact points that you need because there are a lot of snaps in that area, you need to zoom in to that area so that the points of interest are not so tiny on the screen.
Don't zoom in so closely that you can't make sense of what it is that you are working on either though.
Also if there is a lot of other stuff getting in your way you should try to hide the other stuff to unclutter your working environment. That's also another thing that is a good habit to get into - try to hide things sooner rather than later, if you are struggling with too many things getting in your way.
4252.11 In reply to 4252.10
yes ...the only problem was that some snaps with same name of snaps are on the same line with little proximity :)
But I can manage with your previous advices or other strategy :)
Show messages: All  1-4  5-11
