Lighting and model color
All  1-8  9-13
425.9 In reply to 425.8
Ok, this is ready for the next beta.
To make it work you'll have to define a keyboard shortcut. You do that by closing down MoI, then editing the moi.ini file (which contains settings). The file is located here: C:\Documents and Settings\[your login name]\Application Data\Moi\moi.ini . You'll add this line:
[Shortcut Keys]
L=script:var dir = moi.view.lightDirection; if ( dir.x == 1 && dir.y == 1 && dir.z == -1 ) { dir.set(-0.5,1,0); } else { dir.set(1,1,-1); } moi.view.lightDirection = dir;
That stuff for L= should all be one long single line.
This will define a keyboard shortcut for L that will toggle the light direction, between the standard direction:
and this alternate direction:
I can help you tweak the script if you want the alternate light from some slightly different direction than that.
It looks like it will be a few more days yet before the next beta is ready.
425.10
Thanks for the new light tweak but I am getting an error when I try to use it.
Did I do something wrong? It's all on one line just like you stated but I can't seem to get it to work :(
Regards,
Richard
425.11 In reply to 425.10
___________
___________
It wont be ready until the next Beta (which hasnt been released yet).
425.12 In reply to 425.11
Yup, sorry for the confusion - what I wrote is what will work, once you get the new beta in a few days from now, it won't work on the current beta.
425.13
Ok :)
Sorry for the misunderstanding.
Richard
Show messages: All  1-8  9-13
