Lighting and model color
All  1  2-13
425.2 In reply to 425.1
Hi Richard, there isn't currently any way to do these.
Object colors I don't think will be ready for V1, I've kind of lumped object properties along with grouping and object management system stuff that I have postponed until V2. I know this is a bit weird, but in time this will get fixed up.
I should be able to cook up something for the lighting pretty easy though, I've had it on my list for a while I'll see if I can jam that out now for the next beta... It will probably just be a new scriptable method that will allow triggering it by a keyboard shortcut.
425.3 In reply to 425.2
your "paper list" must be something curious! :D
Take it on side for future museum expositions :)
425.4
Thanks once again Michael! As usual your always ready with an answer :)
Of the two issues I stated I think the lighting is the most important one for me. I can live with one color for now as it doesn't interfere with modeling.
You stated that you'd tie the lighting to a hot key. Does that mean a toggle on/off for directional lighting? Just wanted to make sure I understood you.
Thanks again!
Richard
425.5 In reply to 425.4
Not toggle on/off, but toggle the direction of the single light. So it would flip between 2 different directions on every keystroke.
Or another possibility would be to assign different light directions to 3 or 4 different keys, so that pushing one of those keys will set it to that assigned direction.
I'll be making the light direction available to scripting, so there will be a couple of possibilities like this for changing it.
> Thanks again!
You're welcome!
425.6
Thanks for clarifying Michael.
That sounds fantastic!
425.7
Having the light follow the viewport would be very helpful, and pretty easy. Otherwise, the underside of a model can be rather dark... :)
425.8 In reply to 425.7
Hi Crusoe, that's how it currently works. The new option also works this way, you get to specify a new direction but it is defined to be relative to the current view.
MoI uses a slightly unusual type of double-sided lighting to help reduce the amount of darkened areas in a scene. For example if you draw a sphere if you look at it you can see that there is a band of darkness only around the middle of the sphere instead of the back region of the sphere being totally dark.
This is pretty unrealistic lighting, but it helps to reduce the dark areas to smaller bands and shows off more contours of your objects.
425.9 In reply to 425.8
Ok, this is ready for the next beta.
To make it work you'll have to define a keyboard shortcut. You do that by closing down MoI, then editing the moi.ini file (which contains settings). The file is located here: C:\Documents and Settings\[your login name]\Application Data\Moi\moi.ini . You'll add this line:
[Shortcut Keys]
L=script:var dir = moi.view.lightDirection; if ( dir.x == 1 && dir.y == 1 && dir.z == -1 ) { dir.set(-0.5,1,0); } else { dir.set(1,1,-1); } moi.view.lightDirection = dir;
That stuff for L= should all be one long single line.
This will define a keyboard shortcut for L that will toggle the light direction, between the standard direction:
and this alternate direction:
I can help you tweak the script if you want the alternate light from some slightly different direction than that.
It looks like it will be a few more days yet before the next beta is ready.
425.10
Thanks for the new light tweak but I am getting an error when I try to use it.
Did I do something wrong? It's all on one line just like you stated but I can't seem to get it to work :(
Regards,
Richard
425.11 In reply to 425.10
___________
___________
It wont be ready until the next Beta (which hasnt been released yet).
425.12 In reply to 425.11
Yup, sorry for the confusion - what I wrote is what will work, once you get the new beta in a few days from now, it won't work on the current beta.
425.13
Ok :)
Sorry for the misunderstanding.
Richard
Show messages: All  1  2-13
