Why Won't This Fillet?
All  1-6  7-8
4249.7 In reply to 4249.1
Hi OSTexo, I've attached a version that I finished up by splicing together some pieces.
I separated out the top surface and untrimmed it and then stretched up the side walls and then retrimmed it to get back to an original sharp corner shape like this:
Then filleted that, doing those areas all at once to make this:
Then kind of harvest these faces here and paste them into your other model and trim the other model to splice them in:
One tricky part with this is that the fillets made by Moi and SCE have slightly different rotations to their cross-sections, so they don't quite meet up directly - I had to erase the longer fillets along the upper sides and replace them with a sweep to make the pieces meet up easily.
4249.8
Hello,
Thank you very much for the tutorial, it worked flawlessly (as usual). I saved my original rough versions of the model so following the steps took just a few minutes. I made some modifications to the model and the variable fillets to more closely match the actual adapter.
Show messages: All  1-6  7-8
