Menu Align &...
 1-4  5-22
4241.5 In reply to 4241.4
Space between sides of the bounding box seems the more versatile
EDITED: 3 May 2011 by PILOU
4241.6 In reply to 4241.5
> Space between the center of the bounding box seems the more versatile
So you mean something like this would be considered equally spaced:
Because the space between the center of the bounding box of each item would be like this:
Are you sure that would be the kind of result that you'd want? It seems like that would be kind of unusual.
4241.7 In reply to 4241.6
ah you are too speedy :)
I had changed my mind during your send :)
<Space between sides of the bounding box seems the more versatile
because we can past side to side if space =0
so no need that follow script :)
"that gives the total lengh of each bounding box of a selection seems that we can all calculate"
4241.8 In reply to 4241.7
Hi Pilou, yes space between the edges of the bounding box would be similar to how many illustration programs do it.
I think that could be a possible tool to add in the future, do you want to add it to the wiki wishlist?
4241.9 In reply to 4241.7
The only other thing that's a bit odd with doing this in a 3D modeling program is that there are 3 different possible directions to space things in - spacing between the edges in the X axis direction, the Y axis direction, and the Z axis direction.
Any idea of how you would want to control which of these directions would be used?
Maybe instead of using a fixed direction you should draw a line and the spacing will be done in the direction of that line.
4241.10 In reply to 4241.8
< I think that could be a possible tool to add in the future, do you want to add it to the wiki wishlist?
with pleasure :)
done ;)
http://moi3d.com/wiki/Wishlist
4241.11 In reply to 4241.9
< Maybe instead of using a fixed direction you should draw a line and the spacing will be done in the direction of that line.
Yes as the array dir works :)
in fact that is very useful when you have for example many differents profils on the same plan
for make some sweep or loft!
Selection then Space them on the Z axis
Maybe after the existing function alignment for symplify the calculate?
EDITED: 4 May 2011 by PILOU
4241.13 In reply to 4241.12
When you're using auto-place mode for sweep, you don't actually need to make the profiles evenly spaced, they just have to be in a general left to right order.
The sweep auto-place mechanism will evenly space each profile along the rail no matter exactly how they are spaced in their flat position.
4241.14 In reply to 4241.13
yes but I dont see the profils in their sweep result except start and end
I must make some another functions for they become visible and extract them with their posititons
4241.15 In reply to 4241.14
Hi Pilou, I'm not sure if I understand what you were meaning by this message here though:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4241.12
If you want to have a bunch of evenly spaced identical profiles spaced in the z axis direction, then you can do that right now by using the Transform > Array > Dir function.
A special "Distribute" function would only be useful if you had some variety of different kinds of profiles that you wanted to evenly space instead of the same one.
But the way a distribute function in an illustration program usually works is that it takes some rough arrangement of objects and then moves them to make them evenly spaced. It does not normally modify things from one direction to a different direction, which seems to be what you may be talking about since in your screenshot you show several objects generally organized in the x axis direction I guess but then you're talking about spacing in z ?
4241.16 In reply to 4241.15
Say I have plates of some slices of anything
it will be pratical to redraw over them and then call the space function!
for redraw it on the Z axe for make some volumes with loft
Of course the other axes can works for simple spacing
Automatic sweep makes a sort of this but visibily of the slices themselves are hidden
4241.17 In reply to 4241.16
Hi Pilou, so the way a regular "distribute" function would work is that you would first need to roughly arrange those plates to stack them along the z axis direction. Then you could run the distribute function to get them equally spaced.
But the regular kind of distribute function only adjusts objects from their current locations to be exactly spaced, it is not normal for that kind of function to completely re-arrange things like take a 2D flat grid of objects and then transform that to be a single stack in a different direction - that would be a different kind of distribute function.
4241.18 In reply to 4241.16
Hi Pilou, also there is a plug-in that I wrote called MoveSliceToPoint which can be used to help with arranging a number of slices to equal spaces, it is here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2749.36
That's a different kind of thing than how a "Distribute" function works in a 2D illustration program though.
4241.19 In reply to 4241.18
Ah! I have forgotten this very useful one!
Maybe a day a little complet list of all
scripts + a little image will be necessary
because profusion of scripts becomes gorgeous!
In any case a space function will be useful for some tricky cases :)
Ps The beauty of your your plug (moveSliceToPoint)
is that points can have different vertical positions and not a just on a straight line! Even any position in the 3D Space!
So very cool for boats' stations for example ;)
PSS and the more funny!
You can move at any time the profils not used before the next right click !!!
And also select more then one profile in the same time!
Like at the funfair ;)
And the MoveSliceToPoint works also for any Type of objects (curves, surfaces, volumes...) ;)
EDITED: 5 May 2011 by PILOU
Show messages:  1-4  5-22
