3dm mesh file.
All  1-5  6-12
4240.6 In reply to 4240.5
Hi Mark, well some other people have requested it before too, and it would be useful for use with some particular programs like that iPhone app.
So it's not necessarily a bad idea to have it, but I have not yet been able to figure out a good way to do it in the regular file save UI that doesn't seem weird... Something like having 2 different kinds of 3DM files that you could save to from the regular file type list one of which can't be loaded back in and the other is your main save file type is pretty weird.
Maybe at some point I'll be able to add it as some kind of optional plug-in command or something like that so that it won't make for a confusing regular save UI.
4240.7 In reply to 4240.6
Would it not help to have it as a saving option at the end of the list after illustrator ai - RhinoMesh(3dm). Before it saves it gives you a warning that the file will not be compatible back into Moi - asks you to confirm. If it is at the end of the list it is less likely it would be used in error.
4240.8 In reply to 4240.7
Hi 3dcnc,
That would be better than having it right next to it, but I'm still pretty wary about it.
It's pretty difficult to convey this warning information very well - too short of a message can be too cryptic and not explain things enough. Too long of a message tends to make people ignore the whole message.
So I don't quite like to rely on this kind of warning message.
The side effect of saving to the wrong kind of 3DM file and thinking you had all your full data safe could be pretty catastrophic...
4240.9 In reply to 4240.8
Maybe it should save both. if you try to save the meshfile. the backup suface file is overwritten evrytime you use the option.
file2.3dm and file2_mesh.3dm
Sometimes you need to learn the hardway to keep things simple ( I speak from experience). I have run out of ideas for this one.
Thanks for the feedback anyway.
4240.10 In reply to 4240.9
Hi Mark,
So you mean actually modify the file name that the user types into the file save box and stick _mesh at the end?
That kind of file name alteration might be kind of weird for the case where someone was mainly wanting to generate the mesh file...
The way that might be less weird overall could be to have a plug-in that would do this, it could be something like a "ExportMesh3DM" command that you could install and access from a plug-in menu in the future at some point when I've got a menu for such things set up. That would keep it more totally separated from the regular save mechanism.
4240.11
What mesh density would you save out in the 3dm file? NGons?
At the end of the day, this is solely a problem for Apple and their Ipad, not MoI. The Ipad need to be able to read polygon files, like OBJ.
4240.12 In reply to 4240.11
Hi Steve, yeah surely sooner or later someone will make a viewer app for the iPad that can load some common polygon file types like OBJ.
Actually I guess the one that was mentioned in this previous thread here seems like it can do it now:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3827.1
Show messages: All  1-5  6-12
