Rim - First Moi3d Model
 1-20  21-23
4211.1
Hi Folks,
This is my first Moi3d model, having purchased the software yesterday. I have really enjoyed the experience and have learned so much. Modeling is finally fun! :)
Moi3d V2 and Simlab Rendering Edition.
Hope you enjoy.
Steve
4211.2 In reply to 4211.1
Hi Steve, that's a great result - that's really cool that you're enjoying MoI and off to such a quick start with it!
4211.3 In reply to 4211.2
Thank you for your wonderful software... I am really enjoying it.
By the way, running under Parallels on a new macbook pro. Runs in coherence mode perfectly.
Very pleased.
Thanks again
Steve
4211.4 In reply to 4211.1
Great start there Steve, nice choice of colours.
4211.5 In reply to 4211.1
HI Steve,
Great model.
The only thing that i find little weird is the break pad, seem to be very, very close to the interior of the rim.
Unless it is optical illusion.
Denis
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 6.3, Carrara Pro 6.2, Hexagon 2.5 |
| Maxon Cinema 4D R8.2 | Moi 3D V2 |
4211.6 In reply to 4211.5
Hi Denis,
It is very close... but I made sure it missed the rim :) I rebuilt it twice so I could get the angles correct. In the end to ensure I had the biggest disc size possible, I drew 2 curves (the top half) inside the rim (using the rim and hub as guides, then mirrored, joined, planar and extended the caliper to give depth.
Thanks very much everyone for your feedback..
Steve
4211.7 In reply to 4211.6
Nice model and render Steve. I'm guessing you've got a fair bit of experience with another modeller!
Looking forward to seeing more of your work.
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
4211.8 In reply to 4211.7
Hi Mark,
Thanks very much. Yes, you're right. I have owned Modo since 201, but subdiv modeling seems to be my nemesis. I am alright with small modeling tasks in Modo, but when it comes to big stuff like cars they end up looking like my patio.. all lumpy :( I wanted a modeler that could let me be creative and didn't get in the way.. and Moi has certainly done that. :)
I have just finished the hub bolts, valve and pad plate. I'll upload when it has rendered.. might try a different colour scheme too.
I am seeking some advice for my tyre ;)
1. Can I align text to a curve? I tried yesterday without much success. It is for the side wall of the tyre. I managed to get the Y of yokohama aligned but it was a bit hit and miss using rotate and the bottom to points of the Y to align to a circular curve the same diameter as the centre of the tyre. Is there an easy and accurate way to do this?
2. Also the tread of the tyre. My thoughts are to create a boolean array of blocks or tubes depending upon the style of tread and then diff the array from the tyre. Are there any other ways of doing this?
Thanks again all.
Steve
4211.9 In reply to 4211.8
Hi Steve,
MoI doesn't currently have a function for that, but it is definitely something I want to add in the future.
Currently the easiest way to get text along a curve is to do it in a 2D illustration program and import it into MoI. There is one 2D illustration program called Expression which is available for free from here:
http://download.microsoft.com/download/a/5/d/a5d625a5-2e3d-4e9c-8608-6de48d7b569f/CreatureHouseExpression3_3.exe
One other technique is if you project some curves on to your object you can then do something like a sweep along them to make a tubular cutting object to use for the boolean difference.
Check out here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=817.8
4211.10 In reply to 4211.9
Michael... you are a star! Thanks.
I have inkscape... would that be suitable for the text?
I like the idea of projecting the curves onto the surface too.
Steve
4211.11 In reply to 4211.10
Hi Steve,
I may be misunderstanding what you want to do but projection sound like the way to go. I used that to do a ship's nameplate, projected onto the ship's hull. It works nicely.
Mark
4211.12 In reply to 4211.11
Actually, re-reading your post, I reckon I did misunderstand what you want to do. Is your concern that you want to have the letters projected on the sidewall radially from the centre of the hub?
Perhaps you can do something like the following images? Work out the start and end positions for your complete text, do a circular array of the line markers, then on the vertical add each letter, rotate the letter from the hub centre into position using the line markers as your guide and repeat for each letter in the text. Finally, you can project the curves onto the sidewall of the tyre.
Alternatively, you could rotate the tyre, project, repeat.
Mark
Size: 113.4 KB, Downloaded: 37 times, Dimensions: 1366x768px
Size: 111.8 KB, Downloaded: 29 times, Dimensions: 1366x768px
Size: 104.8 KB, Downloaded: 39 times, Dimensions: 1366x768px
Size: 111.6 KB, Downloaded: 31 times, Dimensions: 1366x768px
Size: 103.2 KB, Downloaded: 39 times, Dimensions: 1366x768px
Size: 103.7 KB, Downloaded: 42 times, Dimensions: 1366x768px
4211.13 In reply to 4211.12
Hi Mark,
That's an excellent method! I will give that a try later. Thanks very much for all of your help.
Steve
4211.14 In reply to 4211.10
Hi Steve,
Yes, I think that would work as well, the only thing is that I don't think that Inkscape exports to the older style AI format, but you could try exporting to PDF format. PDF though is a complex file format and MoI's PDF importer is not always able to make sense of them.
That other program that I linked to before Expression does export to the more simple AI v8 format, and that format is much more reliable for getting 2D data over into MoI though.
Very cool render and sculpt!
4211.16 In reply to 4211.14
Thanks Michael.
In the end I used a combination of sketch (for mac) which exported as eps. Then used Marks advice using lines from centre and rotating each vector text character around the tyre. The only problem was getting the spacing correct as the text is proportional. Oh.. and it took ages! lol.
Thanks again
Steve
4211.17 In reply to 4211.15
Thanks very much Pilou. :)
4211.18
Well, I'm going to call it wraps on this model. Added wheel nuts, adjusted the rake of the spokes, added valve and cap and built the tyre. The tyre was... erm... an experience to say the least, but I got there in the end.
Thanks for your help folks...
Steve
Size: 198.6 KB, Downloaded: 105 times, Dimensions: 1045x800px
Size: 101.6 KB, Downloaded: 132 times, Dimensions: 800x800px
Size: 113.9 KB, Downloaded: 106 times, Dimensions: 800x800px
4211.19
Beautiful! Love the renders. Can't wait to see more !
4211.20
Very nice model and rendering keep it going!
Show messages:  1-20  21-23
