files sizes
All  1-10  11-14
4196.11 In reply to 4196.10
Hi macray,
> For a while the work via separate files will have to make do.
Don't forget the display density adjustment too - that actually makes a pretty big difference to reduce RAM usage on heavier models.
Go to Options > View > Meshing parameters (the settings at the top), and set Mesh angle = 25 degrees, and uncheck "Add detail to inflections".
The display will look a bit more jaggedy but memory use will go down by a chunk.
4196.12 In reply to 4196.11
As this is mainly about piping-this should be helpful. Thanks for pointing at it again.
What you see is what you believe - so don't. (from an Amiga500 demo)
4196.13 In reply to 4196.12
Hi macray - yeah piping tends to make a particularly heavy display mesh so you'll probably see a pretty good memory reduction with the rougher display settings.
Another thing that I'd like to try in the future is something more like make an initial rough display mesh for everything and then go through and in the background calculate denser and smoother ones but only if there is plenty of memory still available.
4196.14 In reply to 4196.9
>Yup MoI.exe is already marked as large address aware.
Awesome. Thanks.
8 GB RAM, ATi Radeon HD 3870
Show messages: All  1-10  11-14
