Scripts to generate epicycloid and hypocycloid gear reducer profiles.
All  1  2-14
4168.2 In reply to 4168.1
Thanks bemfarmer,
Certainly usefull and i will use it for my mechanical projects.
Compliments,
4168.3 In reply to 4168.1
Hi Brian, this is cool, thanks for posting it!
That's great that you were able to adapt the other circular helix array script to make these new curve generators. Seems to work well!
Works like a charm!
Useful for some of crazzy forms :)
Ultra funny indeed !
4168.6 In reply to 4168.5
Could someone possibly re-zip those files for me??? My zip is a bit older and wont utilize the 7z file.. I didnt want to load more software or upgrade my zip utility yet...
Thanks.
4168.7 In reply to 4168.6
Hi Burr,
Here you go...
regards Colin
4168.8 In reply to 4168.7
Thank you Colin.
4168.9 In reply to 4168.6
7zip is free and works great.
http://www.7-zip.org/
At any rate I see someone else re-zipped it.
Cheers,
Nick
Windows 7 x64, Precision T3400, Intel C2Q @ 3 GHz
8 GB RAM, ATi Radeon HD 3870
Revisions.
Switched to "interpcurve" from"curve". (Commented out curve statement.)
Eccentricity is no longer just an integer, it can include decimals now.
Eccentricity change now updates. (Corrected glaring error.)
EDITED: 12 Nov 2017 by BEMFARMER
4168.11
I am trying to get a hypocycloid shaped likE the one in the attachment
but just dont get it ;-( I would be thankful for a tip !
EDITED: 12 Nov 2017 by SIRTOM
Size: 43.9 KB, Downloaded: 28 times, Dimensions: 1448x1142px
4168.12 In reply to 4168.11
Hi TOM,
The two gear reducer profile scripts are poorly named, because they are for generating the rotors for Gear Reducers based upon
either epicycloids or hypocycloids, with an eccentricity. They should be named something like epiGearReducerProfile, and hypoGearReducerProfile.
The mathematics are relatively complex, and come from the cited academic paper.
They do NOT generate epicycloids, nor hypocycloids, although the gear math uses epi's and hypo's as initial math formulas.
So to generate the geometry you show, you should use the hypotrochoid script.
You can look up hypotrochoids on Wikipedia. Hypotrochoids contain hypocycloids, as a subset, when b = d.
(note, the selection window at the upper right for Hypotrochoids may say Epitrochoids, due to my failure to change the options name,
while adapting Epitrochoidscript to Hypotrochoid script.)
The aRadius to bRadius should be 12:2, and the d radius about 5 or 6, and the numcycles = 1.
So I think that your geometry is a hypotrochoid, not a hypocycloid...
4168.13
Good that I asked - I could have tried out parameter combinations for years ;-)
Thank you for the explanation, I will give the othet other script a try !
4168.14 In reply to 4168.13
Works perfectly !!
Show messages: All  1  2-14
