Roof
 1-12  13-23
4167.13 In reply to 4167.12
> You don't like my method? :)
You mean for building the side walls? Your method would work, but extruding a bunch of faces like that is going to make a lot of individual solids, so then you'll probably want to do some extra steps like selecting all of those little solids and doing a boolean union to combine them together. That would work but it just more steps than selecting 2 curves and using Loft...
4167.14 In reply to 4167.13
In fact my method was false :(
I must remplace "Normal" by "Z" :)
Because like this all facets take the same orientation of the first "Normal" face, that is not good for this roof situation!
I will go change the image above!
And you right I must make a Boolean union if I want an single volume
For the speed maybe it's the same?
Select all faces
Make extrude along Z
Select all
Make boolean union
against
select curves
Join them
Copy vertical
Draw a ligne
Make Loft
Select curves + faces plan
Join all
4167.15 In reply to 4167.14
Thanks Michael and Pilou
You have helped me a lot
I'm happy to use this program is really great
and easy to use
good job Michael
4167.16 In reply to 4167.14
Hi Pilou - for doing a loft you don't have to draw a line, once you have the original curve and a copy above it, you select those 2 curves and do a loft to get the surface. You'd need to draw a line if you were using something like Sweep instead of Loft.
Any way that gets the job done is fine of course! But using Boolean Union in that way will rely on the Booleans detecting all the exactly overlapping faces between all the pieces, which should work but it will be doing a lot of analysis and detection work in the boolean to figure that out.
Doing a Loft + Join ends up doing a lot less internal calculations, and just in general a method with less calculations is good because less calculations = less potential for things to go wrong...
4167.17 In reply to 4167.16
yes but in the file given all were separated so take only a perimeter for the original curves was not so easy!
you must click on each extenal segments so 14 clicks
for the faces only 11 clicks ;)
4167.18 In reply to 4167.17
Hi Pilou, you don't have to only click on curves individually - just use window select to grab many things all in one action, like this:
For a case like this when there isn't anything else in the model you can also use Ctrl+A or also in other cases using the Scene Browser Types section can be useful for selecting all objects of a certain type.
But often times if you have a lot of things in one area, just using a window selection as shown above can save a lot of clicks! :)
4167.19 In reply to 4167.18
Yes but for the last file given by Tony 77 (Wireframe) it was not possible without some manipulations :)
There were "internal edges"
Or I miss something : does exist External selection ?
Loop selection don't work in this case!
EDITED: 4 Apr 2011 by PILOU
4167.20 In reply to 4167.19
Hi Pilou - when I open up Wireframe.3dm from above I get the image shown in the above screen capture with just the outline wire... Do you see something different?
The other file Roof.3dm file has more stuff in it.
4167.21 In reply to 4167.20
Sorry it was the wireframe3.3 not the last ! post # 8
4167.22 In reply to 4167.21
Hi Pilou, I see... But you still don't necessarily have to do individual clicks - instead you can hide things that are getting in your way.
Go to the scene browser Types section and click on the eye for "Surfaces" to hide all the surface pieces in 1 click.
Then after that, a few crossing window selections like this:
Now you can hide those and then you have just the outline that you want to work with showing, or you can also invert the selection. But if stuff is getting in your way you should generally try to hide it earlier in the process as you are working.
Note that for those window selects I'm doing a "crossing" selection, where it starts on the right and drags towards the left. That kind of dragging selects any object that touches it in any way, if you start on the left and drag towards the right it only captures things completely inside the window. The crossing rectangle (right to left one) is shown with a dashed border instead of a solid border.
Also if you know that you are going to want to make a joined outer ring of lines, it's good to just do that during the earlier stages of the model like in that previous Wireframe.3dm file, before you even add the other internal stuff.
4167.23 In reply to 4167.22
Yes the dashed box selection is good for that :)
And the Browser makes miracle's selections!
EDITED: 5 Apr 2011 by PILOU
Show messages:  1-12  13-23
