Function Orient
All  1-11  12-19
Is that more clear? :)
Of course the line / line with no Scaling is cool but i will whish to slide on the curve for some reasons :)
EDITED: 30 Mar 2011 by PILOU
4157.13 In reply to 4157.12
A little bit... :)
It is possible to get the slide along curve, but you have to position the source frame to the correct position so that it will map to the natural target location on the curve.
The main thing to focus on is that whatever direction the z axis is pointing towards in the source orientation, will get mapped to the curve tangent direction in the target placement, since when snapping on to a curve the axis is placed with the z axis along the curve's tangent.
So for example with your last image, if your source orientation is positioned with its z axis like this (z in red here):
When the target position is placed on to the curve, that same direction will be mapped to the curve tangent, here the curve tangent shown in red:
So the red line in the first image maps to the red line in the second image....
In other words, the z axis of the source position is what will end up matched to the z axis of the target position. Similarly the x axis of the source position matches to the xaxis of the target position and same with y.
The reason why it is mapped in this way for default positions is that it makes it easy to position a planar curve perpendicular to a different path curve.
But if the default mapping does not do what you want, you need to adjust the orientation by flipping some of the axis directions around instead of only using the default orientation.
My advice is to not worry so much about getting the "slide along curve" motion just by itself - instead try to focus more on what final position you want to get as the end result. If you are focused on the final position more it means you can do some axis rotations on the target position to get the final position how you need it.
I'm still not sure if you are able to get what you need now or not - doesn't the orient line to line tool give you an easier way to get the final position you wanted for your particular case?
4157.14 In reply to 4157.13
< So for example with your last image, if your source orientation is positioned with its z axis like this (z in red here):
This is my result of manually use the Function Orient! If you see on the image the little lift corner you will see the default orientation ;)
The line/line is perfect for one position on the curve !
(little trick) just take the first point on middle on the baseline objet, the second anywhere to the end line base object, and you will have easily the postion on the curve with a perpandicular helpers line ;)
And then call the normal orient for slide the object on the curve! Bingo!
But, now , i have learning by heart the tripod position for arrive on a curve // on the ground for win a using step function! :)
So now I am a little more strong for make video about the subject!
Thx for the help and sorry for my unprecise first image!
Just a question : does the last tripod of function "orient" position is memorised when you closed Moi?
And regulate the size of the tripod of the function Orient?
In the moi Ini?
and this one!
I have all disable Snaps except "On", (because I want slide on the curve) in any menus, in any options
But there is always trouble when I pass over the "ghost forms" of the original object position when I slide the object on the curve!!!
How avoid that?
If I make Alt, I am not more on the curve! :)
4157.17 In reply to 4157.14
No - in general points that you pick within some command are not remembered between sessions, and orient is no different than any other command in this regard.
> In the moi Ini?
No, there is not currently any setting for that in the moi.ini file - those line are scaled so that they will be a size of 150 pixels on the screen though, so they will maintain a constant size whether you're zoomed in or zoomed out.
4157.18 In reply to 4157.16
> How avoid that?
You could move the original object off to the side somewhere so it wasn't directly on top of the area that you wanted to orient it on.
Or another possibility is to assign a name to your object and then while you are within the orient command you can go to the Scene browser Objects section and hide it and the wireframe outline of it will then be hidden.
Thx for all these precisions
Show messages: All  1-11  12-19
