Offset to a different layer
4135.1
Do you have a script to offset a curve to a different layer than its parent? I searched but didn't see one. I presume that the layer would be specified in the script line somewhere (i mean in the shortcut key line).
Nick
EDITED: 21 Mar 2011 by BODINI
4135.2 In reply to 4135.1
Hi Nick -
There is an moi.ini flag that you can set that will make stuff like the output from Offset go to the current style instead of inheriting the input object's style.
To set it, open up moi.ini (Options > General > Edit .ini file button), and go to the [Styles] section. In there set this option to n :
[Styles]
GeneratedObjectsInheritStyle=n
With that in place then various commands that generate an output object from an input object, like offset, extrude, revolve, loft, etc... will put their output on to the current style - the current style is the one that has a ring around the outside of its swatch in the scene browser, right-click on a swatch to set it as the current style. The current style is also the one that is assigned to newly drawn objects like if you draw a line it gets assigned to the current style.
4135.3 In reply to 4135.2
That is the shiz-nite! Thanks.
-Nick
