Hidden line toggle?
4130.1
Is there a command to toggle the hidden line view? I did a search and couldn't one.
Thanks for any help,
Nick
4130.2 In reply to 4130.1
OK,
I found this:
ToggleHiddenLine – to toggle hidden line display on or off quickly.
script:moi.view.showHiddenLineCurves = !moi.view.showHiddenLineCurves; moi.view.showHiddenLineEdges = !moi.view.showHiddenLineEdges;
But it doesn't work. I get the error shown here:
4130.3 In reply to 4130.1
Hi Nick, paste in the following in for the command part of a shortcut key to do that:
script: /* Toggle hidden line display */ moi.view.showHiddenLines = !moi.view.showHiddenLines
Then pushing that key will have the same result as clicking the "Display hidden lines" checkbox on the View palette.
4130.4 In reply to 4130.2
Ah geez... it's been one of those weeks...
Now I feel like a complete tool... :-\
This was right below:
v2
script:moi.view.showHiddenLines =! moi.view.showHiddenLines;
[Edit]
Thanks Michael. I think I was typing this while you were typing your reply.
4130.5 In reply to 4130.2
Hi Nick, I think that other one you posted above worked at one point in v1, but the script properties that it is using changed at some point so use the one I posted above instead.
4130.6 In reply to 4130.5
My second posted version works as well. Is there any noticeable difference?
4130.7 In reply to 4130.6
Hi Nick,
Nope no difference, they're both doing the exact same thing. I just didn't see your other post yet when I wrote that one.
In the one I posted that part that has /* */ around it is just a comment, I try to stick those in there so that you might have a better chance of remembering what that thing does when you go look at your shortcut keys later on at some point.
4130.8 In reply to 4130.7
Thank you.
4130.9 In reply to 4130.8
No problem Nick! :)
