Shedding some light
I would like to ask you to shed some light for me here... This is a sample curve and solid created from it.... If you select the top face and run a fillet of .04, one corner kindof goes bonkers..
I couldnt find anything that would indicate for me what is happening. Nothing needs to be "fixed" for this... I am really looking for more of an underlying explanation of what happens at this area as it is just a single curve from a larger object that someone is having issues with and I am helping out.... Your explanation may help me track down whats going on in the larger model...
4125.2 In reply to 4125.1
Hi Burr, that's pretty freaky looking...
So I think this is basically related to the problem of having a fillet radius that is large that goes around a tight bend, where the fillet radius is actually larger than the radius of the bend itself.
That kind of thing has a natural tendency to produce a kind of bunching and self-intersection between the fillet's cross sections - a fillet is basically created through a set of cross sections similar to a Loft internally.
A radius larger than the bend it's going around produces cross-sections something like this:
The bunched up area of that surface where the cross-section pieces are colliding into one another will tend to make a bad quality surface there, it will tend to have strange wiggles and fold back on top of itself and stuff like that.
Then you get a weird result in your particular case here for the corner patch when the corner patch is trying to match up nicely and smoothly to that jumbled and chaotic area.
You can kind of get more of an idea of what's going on by looking at the result of some smaller radius values before you get to the 0.04 value:
Here's what it looks like at 0.01:
And at 0.02:
And at 0.03:
So note that as the fillet radius increases, the upper edge here becomes smaller and smaller and is starting to get somewhat awkwardly formed - that's due to something similar to the bunching problem as shown in that 2D illustration above.
4125.3 In reply to 4125.2
Ok thanks.... It wasnt apparent for me that it was the bunching thing...
