Suggestions?
 1-6  7-26  27-46  47-63
4123.7 In reply to 4123.3
Hi all,
I'm impressed by all your suggestions and especially by your efforts. Hopefully, all this work was done not just for me.
I think I have found a fairly good analogy to express what I mean when I say I don't like to use such and such programs, I do a little bit of programing from time to time and though it is quite possible to write a windows app in strait C, I think anyone will agree that it is much easier and much less time consuming doing the same app in C++ or easier still (in my case) with Visual basic.
I'll admit also that at this time, I don't really know what I'm going to do in the near future. Currently, I'm doing mostly things like this http://latelierdefelix.com/ArmopireBassCaro.jpg or this one http://latelierdefelix.com/ArmoirePointeDiamant-10-finl.jpg.
Practically, all the details on these two are done by hand and all the finishing product are homemade. Yes, I know, I'm crazy, especially considering the time it takes and the price I got for them. Though I love doing this kind of work and it makes me feel good I basically get paid minimum wage if not less. The only good thing I realized is that my work comes up on the first result page of a google search. So I though of exploiting this by creating some kind of virtual showroom to show what I can do. And while at it I might as well think of something to get a pay raise. So I thought of adding carved details to my work but instead of doing those by hand I thought of using a homemade 4 axis CNC. Also, since I have no idea of the market for this kind of work, I would like to spend as little as possible. This is why I'm here at the Moi forum, at $300 compared to $1K for Rhino, I think I can afford it at this time even if MOI as a bit less features then Rhino, it seems easier to use. All the work I would do is for my own use basically and at this time I don't think I'll ever do some production type of work. I'm more in a custom and unique type of work mood but we never know.
wzhang, your designs are very nice and I like the idea that they could be done in MOI. Especially since such floral details could be something I would put on my own design. Fortunately for me, such details are just that, details, in your case, these details make or break the whole object. If you add the fact that they would be done on wood with a CNC the end result would probably never be as nice and clean as yours and I can live with that especially that I wouldn't like my work to look like I used plastic wood pored in some mold. I'd prefer by a long shut that it would look like hand made. I even thought of using the CNC just for roughing and finishing by hand.
Thanks to every one, I think I'm going to like this place very much.
Regards,
Felix
4123.8 In reply to 4123.4
Burr,
please don't put in to much effort in this, it would make me feel bad. I'm a fairly old guy and it takes me more time then I would like to learn new stuff. But I can see from post here and others that MOI is an excellent program and it seems fairly easy to work with.
With all the replies to my post, I have plenty of work on my plate for now.
Regards,
Felix
edit: Sorry I missed your second post!
EDITED: 17 Mar 2011 by FELIX
4123.9 In reply to 4123.8
Hi Felix,
my example didnt take any time at all, dont worry... The point of my example was basically showing the result with only "2d curves"...
The last 2 pictures you showed would be done easy with MoI alone as solids....This would be your best bet.. The previous ones, that showed leaves and things more like "Vines" or branches and stuff, could be acheived with the 2d geometry and BobArt... Good luck.
4123.10 In reply to 4123.4
"Although STL can be sent to you CAm package and machined, it will be linear at some type of resolution."
With the exception of some high end machining software like Delcam, very few 3D cam packages send anything other than linear data to the CNC machine. Sure, a CAM package may import a nurbs model, but most likely its not sending spline coordinates in G-code to the machine. So starting with a polygonal model is somewhat irrelevant if the polys are small enough so they won't be seen in the finished piece. And that, of course, is also related to the material, tool size, feed rate, spindle speed, etc.
4123.11 In reply to 4123.10
The toolpath is calculated from the original NURBS surface, and in this particular CAM package, you have options of the tolerance that the toolapth is calculated off of.. The polygonal model would be dictating the staight lines and breaks and the calcualtion gets very heavy fast, on a polygonal model... The NURBS surface is far more desirable...
A toolpath would choke on a multi-million polygonal count, where it would be a breeze on the same NURBS surface, to acheive the same "curvature resolution", at say, .0001.
I just made a simple curved NURBS surface, then created a polygonal model from it.. The 3dm file is 17.9 KB and the STL is 62.6 MB. The toolpath caluculation on the 2 was 4 seconds for the 3dm file and 4 minutes for the stl...
EDITED: 17 Mar 2011 by BURRMAN
4123.12 In reply to 4123.5
thanks for the info, lots of stuff to digest and sorry for the delay.
Though I'm not sure yet, I think this 2.5d mechanism as you call it, could be the way to go for many if not all the details I would want to add to my work. I have both Rhino evaluation and ZSurf4 and tried a couple imports into Rhino. Following zsurf suggestions, I managed to obtain a decent looking shaded view. But the same file loaded in BobCad looks like the "meshing" is way to coarse and of course I have no idea how I could improve that in BobCad. I finally downloaded the no save version of MOI and imported the same file and I was surprised that it looked much better then in the other 2 programs. But I'm curious to know which programs renders the most faithful representation of the true relief surface because that's the one that will be carved by the CNC? The same would be true with 3D printing I assume.
As a suggestion, a MOI trial version something like the Rhino 25 save version could be ideal to explore the full potential of MOI without the pressure of a deadline.
In this post here http://moi3d.com/forum/index.php?webtag=MOI&msg=602.8 I found a paper about UDT (Universal Deformation Technology) as implemented in Rhino 4 and if I understand all this correctly, it would be more then enough for the kind of stuff I want to do. Is there by any chance something equivalent in MOI? Say for example I've created some kind of an embossed medallion on a flat surface in ZSurf and I'd like to kind of "apply" it on a cylindrical object and make it an integral part of this solid object.
edit: I found my answer, Zsurf can create the "bump" surface on a cylinder and other forms directly. Then I suppose MOI can deal with the rest of the modeling to create some solid.
I think what I'm asking is should I go with MOI or for Rhino especially if one thinks a bit long term. I wouldn't want finding out later that trying to save some money today I end up spending more tomorrow.
Many thanks,
Felix
EDITED: 18 Mar 2011 by FELIX
4123.13 In reply to 4123.12
Hi Felix,
If you're loading the same .igs file into each one, then each one actually has the same true surface data to work off of, you're just seeing differences in the on screen visual representation of the surfaces. MoI just happens to have a particularly nice on screen realtime display.
3D printing is a pretty different process than CNC cutting - for 3D printing you will generally need to output an STL file which is made up of triangles, and whatever is exporting from the IGES surface to triangles will have some controls to control the density and it will probably be done at a fairly higher density than the on-screen display is showing.
No, MoI does not have any equivalent to those UDT tools in Rhino right now, but it is an area that I want to add in MoI in the future. Those tools in Rhino can definitely be useful, and there are several people that use Rhino in combination with MoI to have access to those particular tools in Rhino.
But it sounds like you also found out that if you want the Z-Surf result wrapped around a cylinder you can do that with an option in Z-Surf for that particular case instead of needing to use Rhino UDT.
Well, Rhino is more difficult to use - it's set up to be most comfortable for people with an AutoCAD background. If you have spent a lot of time with AutoCAD before then it's an instant great fit, but if you are not familiar with AutoCAD then some of the things in Rhino will probably feel pretty odd and kind of archaic like the command line interface.
MoI is more oriented towards someone who may not have a lot of prior experience in CAD and so it has a lower learning curve and is generally easier to use.
It can be a good strategy to start out with MoI and then also add in Rhino later if the additional tools in Rhino would be useful for you.
It's definitely worthwhile to spend some time with the trial versions of both of them to see what feels the most comfortable to you.
4123.14 In reply to 4123.13
Michael,
I appreciate a lot your thoughts on choosing between MOI or Rhino, there seems to be some wisdom in what you say.
I've been trying Rhino for a little bit now and unfortunately for them it keeps crashing on me and they imply it's because of my video card. This may be true or not, I don't know, I just know every other apps. I've tried don't crash, so I'm a bit skeptic. I'll give myself the time to learn as much as possible on MOI before making my decision.
The only observation I can make about MOI at this time is that there is no layers and since "drawing" a complete piece like the "armoire" will require quite a few parts, I know by experience the screen will become over crowded and this can be a problem. But since I have BobCad I'm thinking already of importing each part created in MOI and create a single layered model there. If you think of a better solution please let me know.
If I understand correctly NURBS are basically mathematical objects and as such the resolution and or precision of a true surface is only limited in theory by the numerical precision of your computer. But in practice, for displaying or when some meshing is required (which must be almost all the time) the resolution and or precision must be limited by quite a bit such that it can be processed in a reasonable amount of time.
Regards,
Felix
4123.15 In reply to 4123.14
I'm very impressed with my first real trial of MOI. After viewing a few videos from Pilou, (yes I speak french) and reading some parts of the help files, I realized the following in less then an hour.
Unfortunately, I've opted for the no save version so this is just a captured image. CAN I CHANGED THAT TO THE 30 DAY TRIAL?
There are a few things that I don't understand and I'd like your input. Observing the object (hi zoom) in the viewport, I see a lot of jagged edges almost as if there are hole in the adjacent surfaces, are these just display artifacts or something else? The reason I ask this is because I want to render object like this and would like the result to be nice and clean. There are also some part of the surfaces that look as if the normals are not right, if such things exist in NURBS. This object was build by joining surfaces and beside its name it says it's a joined surface, is there some way to make it a solid, if so, how?
May be this next question is more for Burr, now I would like to add something like a medallion centered in the middle of the curved surface, say something like on the top of wzhang nob for example. From previous posts and readings, this could be done via Z Surf but I'd like to know if there are some alternative solution that could be done directly in MOI especially for relatively simple geometry. For example, I could create the outlines I would need on a flat plane or a cplane, project them on the curve surface where I want them, then create the required profiles and use the appropriate construct tools to add volume, etc. Say that I do just that, the result would be like the medallion was just applied on the surface and not be part of the object, wouldn't it better to say make a hole in the surface, I forgot that I could possibly union the medallion with the object. I'm asking all these questions because I'm thinking of both the rendering and the toolpaths generation steps. Lastly, there is always the option of creating the medallion in BobCad/Art in part or in whole.
I think I'm looking for ideas on how one should or could proceed to do this kind of work maybe some kind of workflow. Are there "good" books one could read to kind of self trained on 3D design strategies with the idea of building the actual object?
Felix
4123.16 In reply to 4123.15
Hi Felix, For the question part to me, you have described exactly what to do!!! I would model the medallion on the pillar the way you describe. The only reason to use Zsurf or BobArt, is if you are needing some kind of "Very organic" type of look or surface... Like a tree limb "WITH BARK".
Your model is nice. Yes, it should read "SOLID" if the surfaces were well formed and joined properly... If it reads joined surfaces, then those gaps most likely exist.. For me, the fastest way to learn MoI is the 3 tutorials that come with the help file... Michael covers many aspects, even basic NURBS modeling is learned from these.. They are very nice to watch. Short, concise and packed full.. Not painful like other video tutes.
4123.17 In reply to 4123.14
Hi Felix,
quote:
The only observation I can make about MOI at this time is that there is no layers and since "drawing" a complete piece like the "armoire" will require quite a few parts <...>
Actually, MoI does have a layering mechanism, it's called "Styles" in MoI since it is a grouping mechanism that controls the visual color of the objects assigned to it.
To use it open up the scene browser, by pushing this button in the lower right area of the window:
That will open up the browser pane, and then you can go to the Styles section, which looks like this:
There are various actions that you can do in the scene browser like hide or show an item slot by clicking on the eye icon, selecting them by clicking on the text part of the item's line, assign selected objects to a particular style by clicking on the swatch rectangle, locking, deselecting, ... See here for some more complete info on it:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#scenebrowser
When you export to BobCAD, the styles assignment in MoI should translate to layers assigned within BobCAD.
Yes, this is correct - a NURBS surface is what is called a "spline" - it's a mathematically curved surface.
It depends on what particular operation is taking place - it needs to be meshed for display because a display mechanism needs to use your video card hardware and video cards only deal with triangles.
But other kinds of calculations like surface intersections or booleans will use numerical techniques that interact directly with the NURBS surface.
4123.18 In reply to 4123.15
Hi Felix, it looks like you're off to a great start!
An answer to this question:
Yup, the no save trial and the 30-day trial are separate things, you can have both installed on your system at the same time.
Just when you install the 30-day trial don't put it in the exact same folder that you've already installed the no-save version, and then you can have both of them on your system.
You don't need to do anything special to change to the 30-day trial, you just download the 30-day trial installer and run it - it's a separate installer from the no-save trial version.
4123.19 In reply to 4123.18
Michael,
many thanks for all this info, especially the layer equivalent in MOI ie. styles and for the info on both version.
I want to mention again that I'm very impressed by MOI. I consider myself to be very newbie at this time and I can only imagine how productive I'll be with more experience.
"But other kinds of calculations like surface intersections or booleans will use numerical techniques that interact directly with the NURBS surface."
Is it the same for sweeps, lofts, etc? I know, I'm a very curious guy and I figure that if some operations are more like math function and others are more of an iterative type, the result of these ops. may differ in relative quality. For example, I notice the 1 rail sweep I used seem to proceed by strait line segment to approximate the curve part of the rail. If this is the case then I would ask is there a way one can "control" the step size or would it preferable to use another operation if possible of course.
I use a join operation on all the surfaces of my shape and MOI reports it's a joined surface and not a solid as I would have expected. Would it be better to use a Boolean union instead?
Another observation, the rails I used are made in 2 parts, a strait line and a some spline I would believe joined together. When I select the original rail it's all selected but when I try to select the edge of the sweep surface, Moi select only a single part at a time. This behavior makes me curious to understand what's going on.
Regards,
Felix
4123.20 In reply to 4123.16
Burr,
thanks for your input though I think I messed up bit. I requested your input because of your knowledge of BobCad/Art. What I was trying to say about "drawing" the medallion is yes I could use Z Surf especially if it's "organic" and it could be done in MOI if the geometry is relatively simple as your example, maybe using the method I describe earlier and what I didn't really mention is that it could be done in BobArt as well.
I think I answered my own question in a way and I'm sorry I bothered you with my self questioning.
Regards,
Felix
4123.21 In reply to 4123.11
"A toolpath would choke on a multi-million polygonal count, where it would be a breeze on the same NURBS surface, to acheive the same "curvature resolution", at say, .0001."
An older machine with a hardware controller would choke on that, but it also would not be using splines either. With a modern PC based CNC controller, the file size is irrelevant as long as the PC can send the data fast enough to the machine.
Of course using smaller linear moves increases the file size of the toolpath. However, just because the toolpath file size is large does not mean it cannot be machined sucessfully. Perhaps your system uses arcs and straight line segments? Using arcs would account for a smaller toolpath file size.
Can you post some of the G-code?
4123.22 In reply to 4123.21
I'm speaking about "Generating" the "toolpath", not the gcode that comes from it or the actual cut at the machine. The program that he is using tops out at around 100 MB... (Trying to bring in a 100 mb + STL usually doesnt work, let alone, toolpath it..)
Yes, the software he is using has a "fit arcs" selection, which will turn a 30,000 lines of code file into a 6,000 line file, but again, this is not really the area I was refering to...
4123.23 In reply to 4123.19
Hi Felix,
> quality.
Loft is something that's calculated directly, but Sweep does go through an iterative fitting process, in a way the sweep is kind of like an automated loft that cooks up a bunch of profiles starting with a small number and measuring how accurate the result is and adding more profiles until the generated shape hugs the rail curves to a small enough distance.
But the error of such iterative functions is checked, in MoI the refinement will continue until the result is accurate to within 0.001 units.
> part of the rail.
Well these iterative methods actually produce curve output, the curve just gets more control points in it as it gets more refined.
The only way you should be seeing straight line segments in your sweep is if your rail curve is actually made up of straight line segments instead of being a curved shape itself.
Can you please post an attachment with the 3DM model file of your sweep so I can take a look at it and see what you are referring to?
> <...> or would it preferable to use another operation if possible of course.
Well, which tool is best really depends on the situation a lot - it would help a lot if you would post the model file to give some more specific context to what you are describing.
Well, that again depends on what particular problem you're running into - do you possibly have a surface missing leaving an open hole in the model? If so then for a situation like that you need to model a surface that fills in that hole and then join that in as well in order to make a fully closed skin. If you could post the 3DM model file that has your non-solid joined piece in it, that would help me to give you some more specific advice.
Boolean union (and the booleans in general) are more oriented towards intersecting objects with one another and removing some material from them. So for example if you have 2 cubes that are partially pushed through each other you would want to use boolean union which will intersect them and remove the area that is on the interior.
If you have a set of surfaces that all touch each other at common edges, where no material needs to be removed from anything then that's when Join is the right tool and not boolean union, although boolean union will often work the same for that, it will just try to do a lot of additional work to intersect things as well though.
> what's going on.
Could you please post the model file so I could load it up and take a look at it?
If you have a rail curve that has sharp corners in it and is also not a planar shape, then that can cause the sweep to be made in individual sections along each smooth piece in between the sharp corners and you can end up with several disjoint objects from the sweep in that kind of a case.
If you have sharp corners in your rail and all the rail segments are on a single shared plane, then it will do corner mitering to make it all one piece.
But if you can post the model file that would help me to see what you're running into - it's really pretty hard for me to guess just by a written description because there are quite a lot of different things that can cause different results to be generated...
4123.24 In reply to 4123.23
at the time I wrote message 4123.19 I had only the no save version but I downloaded the 30 days version. Since I had to start from scratch I tried a few different things. Instead of creating the faces 1 by 1 and joining them into a close volume, I used booleans ops, a 2 rail sweep and I used a fillet instead of the 1 rail sweep.
I haven't finish what I wanted to do but I uploaded the new file as requested. This new version doesn't present the same qualities as the jpg I shown previously. Basically, we can't compare the two, this one seems much better and MOI reports it's a solid. Also, I deleted most if not all the construction items I used but if you try to select edges around the fillet or the sweep you will see that only a single part of a edge can be selected at a time and this may add a bit of complexity if further operation are required, unless of course if there is way to rejoin those parts into a single element.
I understand that it must have been pretty difficult to figure out what I meant from just a few line of text and a jpeg. I apologize, from now on, I'll supply a file.
Out of curiosity again, I can foresee the need of say warping a rather simple shape like the (flat) medallion in my file to fit on the curve part of the post and I think it will most likely be most of the time on cylindrical shape like in this case, do you think it's possible to write a script to do just that? Before you even think of it, I'm thinking of writing it myself of course but I would just like to know if you think it's possible with the currently available MOI JavaScript classes, methods, etc?
Regards,
Felix
EDITED: 21 Mar 2011 by FELIX
4123.25 In reply to 4123.24
Hi Felix,
I tried selecting some various edges in the model and I couldn't see anything unusual...
Maybe for this case I might need both the model and also a screenshot that shows the particular edges that you are worried about.
But it is normal to have edges that surround each surface - that's part of how NURBS surfaces work, each surface has a trimming boundary and that trimming boundary is made up of edges.
I can't really see anything out of the ordinary or that would cause any concern with the structure of your model there. But also I'm not sure exactly which pieces of the model you're referring to by the sweep and the fillet - since I didn't watch you actually construct the model I may need a bit more description yet to follow along with your question...
One thing that will generally happen is that if you have curves made up of various sub segments (where they can be separated into individual pieces using the Edit > Separate command), that will tend to generate one surface for each of those segments. That's totally normal for shapes that have a sharp corner in them, but if you want pieces that are smooth to one another to generate a single surface instead of multiple surfaces then you want to make your curve structure have single large segments in it instead of having the smooth pieces made up of multiple small segment fragments. One easy way to tweak curves to remove segmentation like that is to use the Rebuild command: http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild but really a better way than that is to just draw larger segments for smooth pieces more from the beginning rather than drawing a smooth curve portion in little bits and pieces.
No, that's way out of the scope of what's possible to do just with scripting.
Warping of surfaces is actually a very involved process, to do it requires a major reconstruction of all the surfaces and edges in the solid. For example if your base surface that you want to warp is a plane, that surface only has 4 control points at its corners - a surface with 4 corner points cannot be reshaped just as-is to have a cylindrical shape, it has to have a lot of additional control points added into it. So it's a quite tricky process to do this to all the surfaces of a shape and also to all of its edge curves.
Rhino added some tools for this in the Rhino v4 version, so if you need to do this kind of warping right now you'll need to use Rhino for that part of your modeling process.
It is an area that I plan on working on adding to MoI in the future though.
4123.26 In reply to 4123.25
Michael,
sorry I couldn't be more useful with the file I provided, I know there is nothing wrong with it, at least that's what the Rhino analyze tools say.
But I still find this edge thing a bit funny, so I've made a simple test in the file I've attach. When I did a union on the 2 gray boxes on the left I get the red box where the edges at the intersection of the 2 gray box just disappeared as I would expect. I then copied the red box and made a strait line and a curve that I joined and used this curve to create the green and orange shape using a diff. They're normal I suppose but as you can see I would have expected the black and the red segment to select as one edge just as the black edge on the red box. I think I understand where the blue edge on the green shape comes from but I would have thought I would see no edge there.
I'm not complaining about this, it is just an observation of something I wasn't expecting. I think that a break like this can cause a retract in the g-code and on simple objects like these it doesn't matter but on more complex object with a lot of similar breaks, all these retract can increase machine time significantly. If there is a way to rejoin them, I'd like to know about it.
Thanks Michael and though it my not sound like it, I'm very impressed with MOI and it's quite possible that I follow your advice to the letter and get both MOI and Rhino in the end.
Regards,
Felix
Show messages:  1-6  7-26  27-46  47-63
