Suggestions?
 1-10  11-30  31-50  51-63
4123.31 In reply to 4123.29
Hi Felix,
> I want to apologize for the time you spend with my silly
> questions. I want you to know I've appreciated a lot
> conversing with you.
Don't worry, it was no problem! :)
> and I know why I expected a different behavior. I've been
> using Skecthup for a while and when I joined (actually weld)
> segments together they become a continuous curve as in
> MOI but this even after extrusion (push/pull in SU) or many
> other operation.
Yes, the way SketchUp works is pretty different - SketchUp doesn't actually have true smooth curves in it at all, what SketchUp calls a curve is actually made up of a bunch of little line segments. A "weld" type operation in a polygon modeler is a bit different than MoI's Join function. MoI's Join is somewhat more like making a group, but kind of a special group where the pieces know that they are connected together either end-to-end for a curve or edge-to-edge for surfaces.
> It's not a CAM program per say and one of the notes mention
> to watch for breaks or segmented elements because the script
> interpret a break as retract operation.
Well, 3DS Max and gMax are polygon based modelers, so this was possibly referring to needing to have polygons welded together so that the triangles that make up a surface share a common vertex point which then can make it easier for program code to find adjacent polygons to traverse them.
The equivalent kind of "traversability" in a NURBS based program is having 2 surfaces be joined together so that they have a shared common edge rather than being 2 completely separate surfaces that just happened to be nearby one another.
So that edge that you were worried about previously was not a problem in this sense because it was a joined edge between 2 surfaces.
The geometry in 3DS Max and Gmax is made up of triangle meshes, so it's actually chock full of edges everywhere, it just won't display them all the time unless you are in wireframe mode. So I doubt that the CNC Toolkit thing is actually sensitive to just any edge or else it wouldn't be able to handle more than just 1 triangle at a time, that warning was most likely about an edge where it could not find another adjacent polygon that was hooked into the same vertices as the current one.
> But this maybe irrelevant with a true CAM program such
> BobCad that I intend to use.
You could actually find a similar issue in there, but just to reiterate - the issue is probably going to be if you have just totally separate unjoined surfaces as compared to surfaces that are joined together and share a common edge (making a connected skin).
4123.32 In reply to 4123.30
Hi Mr. Burr,
thanks for your time and yes sometimes, maybe more then I would like, I have crazy ideas. This 5 axis CNC idea is probably one of them especially that I would need to spend countless hours to learn a lot of stuff on own. My wife suggested this simple idea of doing something simpler we could do as a team just as we do already for quite a few things. We are close to retirement time and I think this idea of doing even more stuff together is just great.
But I also like to keep my brain busy sort of speak so I'll probably buy MOI even if only to do just that. I might also build myself a small 3 or 4 axis CNC for the same reason.
Regards,
Felix
4123.33 In reply to 4123.31
Michael,
as I said in the beginning, I'm a newbie at all this NURBS stuff and same goes for 3D design. I'm old enough that when I started drawing stuff it was on paper, my first computer was an Apple II and at that time I was in the minority, of course today it's the other way around.
As I said earlier, I'll probably buy MOI even if it's just for the fun of learning new stuff. Unfortunately for you guys here, I'll probably have few more silly questions coming by this forum. I just hope they'll few and far apart.
Thanks again,
Felix
4123.34 In reply to 4123.33
today I tried something easier, just practice stuff and fun, nothing to fancy. Then I decided to render the mirrors just to see, so I exported them to obj which loads directly in Kerkythea and tried a few thing but without success I'm afraid. I assume it as to do with UV mapping or most likely me, I'm afraid I'm newbie at that as well. I though of asking you guys for suggestions on rendering apps that are as easy to use as MOI and as cheap as possible that would make a good companion for MOI and whatever you can think of that I could read to learn as much as possible on rendering?
Thanks in advance,
Felix
4123.35 In reply to 4123.34
Hi Felix, some links to discussions on renderers here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4098.3
There are a few different suggestions in those threads that you could try.
Often times renderers are not particularly focused on being easy to use as a big priority though.
4123.36 In reply to 4123.35
< Often times renderers are not particularly focused on being easy to use as a big priority though.
Except some like Podium for Sketchup ;) http://www.suplugins.com/
4123.37 In reply to 4123.36
Michael, Pilou,
thanks to both of you. Lots and lots of info to digest but I'm not sure I'll live long enough to just scratch the surface of the rendering world. It's like the United Nation where there are a lot of different languages and cultures but no indications where to find the translators.
I came across this video http://www.vimeo.com/4810249 for example. It's not bad per say, some may even say it's excellent but it's almost useless for total newbies. It's what I would call a recipe type document, do this, do that and by the way you can do this and that as well. You see I was a teacher in another life and I know that people don't learn much from document like this because it looks so very easy for someone who is already an expert using these 3 apps together. But for a newbie, after downloading and installing Blender and Lux he or she basically hits a cement wall 4 foot thick. As you well know Michael, I don't think anyone could say that one can learn to just navigate with some ease through Blender UI in a few minutes, maybe not even in a couple of hours. More or less, the same could be said for Lux, MOI and any other apps for that matter.
It's true that one of if not the most efficient method of learning is by <doing> stuff yourself especially when you have a project that gives you plenty of motivation. But that's forgetting the main ingredient, basic knowledge of the context or some basic theoretical knowledge as some might say. Say your goal in life is to become a fisherman but you're a total newbie at this and you come across a video tut that basically tells you go get a boat and a net, throw the net at sea, drag it for a while and bring it in, all this while the video shows the net coming in filled with fish. Sound and looks easy but unless you are a very very lucky guy I would bet a week pay that you'll have a nice day at sea but few if any fish to show for your work. One would think it's easy to figure out what's missing in my example but it's not, especially for an expert kind of guy.
The basic idea behind all this is that when someone knows how to do something it always looks easy to a newbie and when one tries it on his own it's not long before one realize the learning curve is more or less steep depending on one contextual prior knowledge of the task.
Though some may find this an interesting or possibly a boring topic. It made me realize that I need to be a bit more specific about what I'm looking for, especially that at this time, I'm a newbie at 3D design and rendering. Basically, I'm looking for reference material (books and or papers) that are use currently as teaching material in university level programs on 3D design and or whatever programs where rendering photo realistic scene is a prerequisite or that is part of the main program. I'm sure such material exist and it's plentiful and that's the problem and the reason I ask you all, knowing that some of you still have those books from college or universities as we call them here. I can read in both English and French just in case someone think of a french book.
Felix
4123.38 In reply to 4123.37
Hi Felix ...
The best way to get started in MoI is to do the tutorials ... as many as you can do.
As you said, the way to learn is by doing. Some things can be done by just jumping in ... others need some instruction.
My advice would be to do the MoI tutorials first and then try modeling some simple things on your own. You don't have to learn all a program has to offer ... just the things you need to complete the project you are currently working on ... make the next project a little more complex and learn a couple of more things the program will do.
I say this as an old timer (much older than you) who has become fairly proficient with many programs over the years ... but not a true expert in any. I have managed this a step at a time without ever trying to get a university equivalent in any of them.
I make a living as an architectural designer. MoI or Rhino or any of the others will provide the tools for a wide, wide range of uses ... more than I will ever need. So learn the basics you need and grow from there.
Start with MoI and an inexpensive renderer (Like Sim Labs Composer) and enjoy the process. You could spend a fortune on great software and get overwhelmed with complexity.
Enjoy,
eric
4123.39 In reply to 4123.37
Hi Felix, yes definitely a lot of 3D programs can be quite complex. Blender has a lot of functionality but a somewhat unusual UI, and a lot of times just having a lot of functionality available can actually be detrimental to a beginning user because it's easy to just get overwhelmed being submerged in a ton of stuff that is all unfamiliar.
So if you're looking for something that's easy to use, Blender is probably not going to be the right fit for you despite the price being great (free).
Like eric mentions, SimLab Composer could be a good fit for you, give it a try here:
http://www.simlab-soft.com/
Export from MoI using OBJ format and set "Output = Quads & Triangles" and then import that .obj file into SimLab to render it.
re: videos - have you watched the MoI tutorial videos from here yet? :
http://moi3d.com/2.0/docs/tutorials.htm
I have made some special effort with those to make them friendly to beginners, they go along slowly and with additional explanation at each step.
4123.40 In reply to 4123.37
Hi Felix, also re:
I'm not so sure that this kind of material is actually very easy to find...
One problem is that university programs that focus a lot of effort on 3D design also tend to revolve around 3D programs that incorporate a whole lot of functions in them, including things like animation and motion dynamics, etc... Such programs that do a lot of things are just by their very nature more complex to use so they're probably not the right choice for you despite having a lot of reference material on them.
The renderer that Pilou mentioned, Podium, runs inside of SketchUp which you're already familiar with so that might work well for you, I think there is a trial version you can get from here: http://www.suplugins.com/supodium-v2.php
Giving both Podium and SimLab Composer a try to see if they will work for you is probably a good start.
4123.41 In reply to 4123.38
Eric,
I've seen many MOI tutorials, those of Michael I would think and some from Pilou and I also went through the MOI help files to get an idea of what can be done with it. All this before I even download MOI.
Your the perfect example of what I tried to say earlier, you have an architectural design background and years of experience at it using various tools or apps if you prefer. You probably started drawing on paper as I did and progress to using various software when they became available. But being proficient at using MOI or any other app doesn't necessarily make you a DESIGNER, just as having a boat and a net doesn't make you a fisherman you would also need to learn quite a few things as well, for example knowledge of navigation and some knowledge about fish might be very helpful.
A little clarification about my (very limited) drawing knowledge, I followed a course (45 hours) about 30 years ago on descriptive geometry. On my own, I learn to use a couple 2D cad programs that I used very infrequently over these past 30 years. It's just about 1 year ago that I started using Sketchup because it's easier for my client to visualize things that looks almost like real 3D objects then 2D drawing. About 3 months ago, I got this (crazy) idea of creating a virtual showroom to present models of furniture pieces that I would like to build one day either for my own needs or for potential clients. Thus my very recent interest for 3D design software and rendering. The CNC idea came to me about a year ago as well.
Even before I started thinking of 3D modeling and rendering pieces of furniture, I investigated this idea, what makes a particular design more attractive then others? For my line of work this could translate to: how do student learn? In other words, for me just being capable of drawing things will always be insufficient, it's like something inside me was making me insatiable for more, a lot more.
Felix
4123.42 In reply to 4123.41
Hi Felix ..
Yes, good tools do not make a good designer. Good designers are born with a sense of proportion that gets honed over a lifetime of experience and, hopefully, some training and critiques by other good designers. If one wants to design furniture it is important to study good examples in depth to get a sense of what is grace and beauty and what is not. The same with buildings or any other art form.
There are many bad examples of both furniture and architecture out there, too. Sometimes designed by well trained and often famous people.
That said, tools are important. When I drew by hand my clients would get one perspective view of their project or maybe only a flat 2D sketch if the project was small. Now they get 3d views from every angle and detailing I could never take the time for in the past. What they see is what they get so when it is built they don't say 'Oh, I didn't know it was going to look like that!'
At the same time, one does not need a multi-thousand dollar program to create good images. Sketchup (even the free version) is good, though I personally don't enjoy using it. MoI is superb for my 3D work and there are a number of free CAD programs that produce good 2D drafting (Draftsight is one that works well).
I was an early user of AutoCad (at one point a firm I was a partner in used 12 stations) and spent thousands of dollars over time. But it got bloated and cumbersome and more and more expensive.
So my advice is keep your tools simple and inexpensive, make them an extension of yourself, and keep them sharp.
cheers,
eric
4123.43 In reply to 4123.42
Eric,
I basically agree with every word you wrote. I don't pretend or dream of being or becoming a furniture designer any time soon if ever, I'm much to old for that.
At this time, I'm only trying to "reproduce" pieces of furniture I like, mostly period pieces from our past history here in Quebec adding a few details of my own when possible and I also try to use as much as possible the Golden ratio and Fibonacci numbers when sizing pieces to fit in modern houses.
>That said, tools are important. When I drew by hand my clients would get one perspective view of their project or maybe >only a flat 2D sketch if the project was small. Now they get 3d views from every angle and detailing I could never take the >time for in the past. What they see is what they get so when it is built they don't say 'Oh, I didn't know it was going to >look like that!'
My reasons to "draw" 3D models and rendering them are the same as yours, I simply don't want to ear stuff like you mention above. I also think it could be useful at some point to be able to present the same object but with a few different finishes. You mention also that you don't want to spent more time "drawing" then necessary on small project. Same here, especially that pieces of furniture are always a small project.
I don't think I'll have much difficulties learning MOI but it seems to be another story with rendering. I tried a few things via Sketchup and Kerkythea since I know a little bit about them but the results are not so great to say the least. But I wasn't expecting much to begin with, my little previous experience with this route wasn't satisfactory either. I think Ill have a long road ahead.
Regards,
Felix
4123.44 In reply to 4123.40
Michael,
thanks for all this info. I think I have lots of work and study ahead but that's my problem.
I noticed when I export to skp that Moi solid turn into individual entities as SU calls them and when I use obj instead, all solids turn into groups in SU and even the name I used in MOI are present, I'm I missing something on the skp export?
I also tried to export to blender using lwo format and every thing seems fine.
Since my work basically always involve pieces of wood and that I use only 2 types of finish, either a varnish or somekind of "faux fini" using paint on top of varnish. From the little I know, wood seems to be quite difficult to render realistically, the grain pattern causes each faces to look differently, one can add to this, random things like knots, defects or machined edge and carvings. Varnish and paint also present there own set of characteristics that are more or less difficult to render especially when there applied using a brush. I wonder if there exist someway to apply a grain pattern to an object representing a piece of wood such that it look like a real solid piece of wood. I wonder also if any program would be better at this then others even if it's more or less difficult to use and learn?
Don't worry, this may exist only in the miracle department and nobody I know of knows where it is.
edit: I think I've found the miracle department! The procedural wood texture in Blender seems to fit the bill, the docs says:
"Wood is a procedural, which means that each 3D coordinate can be translated directly
into a color or a value. These types of textures are 'real' 3D. By that we mean that
they fit together perfectly at the edges and continue to look like what they are meant
to look like even when they are cut; as if a block of wood had really been cut in two."
Sounds promising...
Felix
EDITED: 27 Mar 2011 by FELIX
4123.45 In reply to 4123.44
With wood textures (in a polygonal modeller, which you will probably have to use to render) it is usually necessary to UV map each mesh object. This map tells the renderer how to lay out the texture on the surface of the object. The reason it is necessary is that you need to control which way the grain flows and which parts need to show end grain features. Plain mapping, like cubic or spherical often don't work properly, particularly where the piece is curved.
4123.46 In reply to 4123.44
Hi Felix,
Which version of SketchUp are you using? Over here if I export a solid like a box for example, when I open it in SketchUp v7 it's a connected set of objects, for example triple clicking on one face in the box selects the entire box.
Objects in SketchUp are made up of multiple smaller entities though, like a box in SketchUp is made up of 18 individual smaller entities - 6 faces and 12 edges, that's just fundamentally how SketchUp functions. But when you export a solid from MoI these various entities are welded together to share vertices in common with each other, that's why you can triple click it in SketchUp to select it all as one object. That's the same kind of structure as if you were to just draw the box directly in SketchUp.
Are you seeing something different than that, or are you maybe more used to working with a group object in SketchUp? Currently MoI just exports regular geometry and does not create group objects, but in the future I'll probably be changing the SKP export to make groups instead.
Some of the advantages to using SKP export rather than OBJ is that with MoI's SKP export you'll be able to get planar faces in MoI to come through as simple planes in SketchUp, including ones that have internal holes in them. OBJ format does not have any way to represent a polygon that has a hole inside of it, so if you use OBJ planes with holes in them will get split in half. Also the SKP export from MoI makes sure to set all the edge flags for smooth surfaces to correspond to the original surface structure in MoI, whereas OBJ import into SKP is probably going to use things like the angle between polygon faces to decide whether to make an edge to be hidden and smooth or not and that can sometimes make the wrong choice for that which can leave some edges visible in what was originally a smooth single surface in MoI.
4123.47 In reply to 4123.46
Michael,
I have the free version 8 and from what you wrote I see that Moi solid don't convert to groups yet. I tried obj first and though it translate to (named) groups I notice the problem you describe above.
Today I decided to give Blender 3D 2.56a a fresh look, especially on rendering and I came across some very good tutorials here. (http://gryllus.net/Blender/3D.html) There is no tutorial on creating wood material and textures but at least this version of Blender is much less alien to me then prior version. I haven't find a way yet to import lwo file in this version, I guess I'll have to make it work before anything else. I also hope I won't have to go the way SteveMacc suggest in is post except may be to add things like knots and other defects, this is explain in one of the video I saw.
Regards,
Felix
4123.48 In reply to 4123.47
Hi Felix,
Yes, but the result that you get from MoI shouldn't really be anything unusual though - you should get the same kind of object structure as if you drew the object directly in SketchUp.
For example, try drawing a box in MoI and exporting it to SKP and loading it into SketchUp.
Then draw a box directly in SketchUp by drawing a rectangle and using push/pull to punch it out into a box.
Don't those 2 boxes behave exactly the same for you? Or do you see some difference in their behavior with regard to how they are constructed out of entities that you were mentioning previously?
4123.49 In reply to 4123.48
Michael,
sorry I didn't reply exactly to your question. Yes, the box from MOI is exactly the same as the box I did as suggested. In the box file, the left box is from MOI, the center box is a box shape made in SU and the right box is a push/pull rectangle made as you suggested. The box2 file show the same box as the one on the right in the box file.
The only difference is the material or the default color if you prefer. It seems like MOI provide its own version of the default material and SU doesn't seem to like it, if you try to select (1 click) the front face on the left box from the box file, nothing seems to happen but the face is selected (entity info). It's probably that phenomenon that confused me.
Though it's not the end of the world, I would prefer personally that MOI solid would turn into a group solid shape in SU and if it's possible, I'd also like the default material to stay as SU default material normally is. Say, I used MOI to create a piece of furniture composed of hundreds of parts, it would be basically impossible to recover each individual part especially if they touch each other, see box3 file where I've drawn 2 cubes (MOI) touching each other, you'll see it's difficult to recover each box, now imagine doing this for a large number of boxes...
This is one of the main reason I don't like the idea of using multiple programs when possible, it seems like there is always something that get lost in translation sort of speak.
Though this may sounds like a critic, it's just an observation and at the risk of repeating myself, the more I use MOI the more I like it and especially I appreciate a lot the time and effort you especially and all the others as well, put in answering my newbie (silly) questions.
Thanks again,
Felix
If you export 2 cubes named + colorised in skp format from Moi
one separated (explosed) and one not separated
Now result in Sketchup will be the same ;)
all cubes will be similar, and they will be not a group!
Now make the same but export as 3DS format from Moi!!!
Import it in Sketchup as 3ds format
result appears as a general group : explode it one time
You will have perfect result ;)
(except colors, no colors in sketchup from Moi till now) maybe V3 :)
And name are replaced by OBJ1, OBJ2...OBJ6, OBJ
you will obtain
first cube = 6 groups!
second cube = one group!
It's not so bad is not it? :)
EDITED: 28 Mar 2011 by PILOU
Show messages:  1-10  11-30  31-50  51-63
