Suggestions?
 1-6  7-26  27-46  47-63
4123.27 In reply to 4123.26
Hi Felix,
> When I did a union on the 2 gray boxes on the left I
> get the red box where the edges at the intersection of
> the 2 gray box just disappeared as I would expect.
That's due to some special handling of plane surfaces - during a Boolean Union the boolean code looks for areas where there are 2 pieces of planes that would end up adjacent to each other and switches them with one larger plane. It can also combine surfaces together if each adjacent surface is a trimmed sub portion from the same original larger surface.
But in other cases it's normal for the very same edge structure in the original objects to come through into the boolean result.
> I then copied the red box and made a strait line and a
> curve that I joined and used this curve to create the green
> and orange shape using a diff.
So when you joined the straight line and the curve together, you have a multi-segment curve. When you use that curve as a cutting object, it will become extruded into a surface and that extruded surface is what will actually be used in the boolean.
When you extrude a joined curve, it is normal for the extrusion to have one surface in it for each segment in your original object.
So for example, extruding a rectangle made up of 4 lines joined together will result in 4 surfaces for the side walls of the extruded result, like this (I turned end caps off for this example):
Here's another example where the curve is made up of 8 joined segments like this:
Extruding this 8-segment curve will result in 8 surfaces, one for each of those segments, like this:
So in your case your curve was made up of 2 segments with the segments something like this:
So with 2 segments in your curve, it then follows that the extrusion will have 2 surfaces in it just matching the same structure as your curve, making a result like this:
So that's where that edge that you're mentioning comes from, it's the edge between the 2 extruded surfaces, and there are 2 surfaces because you had 2 segments in your curve...
Having the extruded object structure be the same as the original curve structure can be useful in many circumstances because it means you can work on the surfaces in the same way as the original curve, like for example with this one you can very easily remove some portions of the object that correspond to your original segments:
Does that help to explain where that edge is coming from?
If you don't want that edge it is possible to get rid of it by making a different kind of curve - instead of a curve made up of 2 sub segments you will instead want to make a curve that is made up of just a single segment. The extruded result of a single segment curve will be just a single surface instead of being in multiple pieces.
You can fuse the 2 segments in your curve together into a single segment by turning on control points and deleting the control point where they join at, or you can use the Rebuild command which will reconstruct a curve and it will make longer single segments out of areas in the curve where there are currently multiple segments that are smooth where they touch each other. More info on the Rebuild command here:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
So in your particular example it looks like the 2 segments were tangent at their join point, so you can use the Rebuild command on that curve to make it into a single segment curve instead of your previous 2-segment curve, and if you then use your new single segment curve as the cutting object in the boolean it will produce the result that you wanted where there is no edge at that one spot.
> I think I understand where the blue edge on the green
> shape comes from but I would have thought I would see
> no edge there.
But I'm not sure why you would expect this - doesn't it make sense for a curve made up of 2 segments to produce a surface made up of 2 faces when it is extruded? It just makes a result that is the same as your curve structure...
> I think that a break like this can cause a retract in the
> g-code and on simple objects like these it doesn't matter
> but on more complex object with a lot of similar breaks, all
> these retract can increase machine time significantly.
I can't remember ever hearing that having a model made up of several joined pieces has any negative effect on g-code production...
I mean it's really a fundamental thing that there will be many different edges in a model even where pieces are smooth with each other, if there was a problem with that it would basically be impossible to model anything with fillets in it - every CAD program that produces fillets will have edges around the fillets where they join together with the other pieces.
The only way to not have any edges in a model is to have the whole model made up of just one single surface and that's not very practical...
Could you maybe describe a bit more about why you're particularly worried about that?
But if you are really worried about it you can remove such edges by making your cutting curves be only single segment curves instead of multi-segment curves, and the Rebuild command can help with that.
But I think it's likely to be something that you don't really need to worry about so much though.
4123.28 In reply to 4123.26
Hi Felix, also having that edge there actually increases model accuracy because with that edge that you don't like in place it means that this area of the model here:
is able to be represented with a simple analytic plane surface rather than just a generic NURBS curved surface as it would have to be if that whole cutout piece was one larger surface.
With it segmented as it is currently, many CAD/CAM programs will be able to recognize that face is a plane and be able to do special case processing on it when doing various kinds of operations involving it like intersection calculations and projections.
When programs get to use special case processing for intersections it helps get both lighter and more precisely accurate results...
So your result there is good - there isn't any need to try and remove that edge - doing extra work to remove it is more likely to degrade your model a little rather than improve it.
Now, one reason why it's good to have it in your particular case here is that it maps nicely to a large planar region of your model - having a large planar region be constructed as a plane that is bounded by edges is good.
But that doesn't mean that having more edges is always good - there are other cases where it can be good to work on removing edges - like if 2 coplanar pieces are going to end up adjacent to one another, it's better in that case to have one large plane instead of 2 adjacent fragments - that's why boolean union merges those kinds of coplanar fragments together.
It's also not so good to have things split up into a lot of little tiny slivery fragments - say for example your cutting piece was a more arbitrary wiggly thing like a sine wave rather than having one piece that was a line, then for something like that it would be likely be better for it to be one long surface without any internal edges in it.
So maybe the part that's a bit confusing is that there isn't one single answer as to what is best - if you have plane that's next to a curved piece like in your last example, it's good for that case to have those as separate faces so the plane can be a simple analytic piece. But then in other cases it can be good to reduce internal edges though too.
It kind of depends on the particular situation, and it can even depend on what you specifically plan to do with the model....
In your particular case that you posted, I can't see any reason for concern about it though, having that segmented with the plane as its own separate face is most likely the best structure for that particular object.
Hope this helps explain things in some more detail! :)
4123.29 In reply to 4123.28
Michael,
Of course I do understand and I know why I expected a different behavior. I've been using Skecthup for a while and when I joined (actually weld) segments together they become a continuous curve as in MOI but this even after extrusion (push/pull in SU) or many other operation.
>But I'm not sure why you would expect this - doesn't it make sense for a curve made up of 2 segments to produce a >surface made up of 2 faces when it is extruded? It just makes a result that is the same as your curve structure...
I figure that since MOI uses the structure of the 2 segments curve I've drawn it makes perfect sense that this blue edge is where it is, that I understand. I also understand that if I want a continuous single curve even after subsequent operation, I just need to build it continuous to begin with, I've tried this and it works perfectly.
I intended to build a 5 axis CNC router at some point and use the CNCToolkit to generate g-code, a MAX script that works both in 3DS MAX and GMAX. This script though very useful because it's free and can produce g-code for synchronous toolpaths for 3 and various configuration of 4 or 5 axis CNC. It's not a CAM program per say and one of the notes mention to watch for breaks or segmented elements because the script interpret a break as retract operation. But this maybe irrelevant with a true CAM program such BobCad that I intend to use.
As I wrote this above I was interrupted and my wife and I took the time to discuss about all this idea of CNC and 3D modeling highly detailed objects and she convinced me to do something much less demanding for old folks like us and her major point his that we do something that we can do together more like a hobby then a business.
But I like MOI enough that I'll probably buy it anyway instead of Sketchup and use it more with the idea of having fun with it then of working with it.
I want to apologize for the time you spend with my silly questions. I want you to know I've appreciated a lot conversing with you.
Felix
4123.30 In reply to 4123.29
Hey Felix,
Home 5 axis CNC would be pretty rough on the ole relationship!!! :o More like a hair pulling event than enjoyable fun... lol
Though, with MoI and a couple other programs, you could do "ART" together, for fun and hobby...
Take care.
4123.31 In reply to 4123.29
Hi Felix,
Don't worry, it was no problem! :)
> other operation.
Yes, the way SketchUp works is pretty different - SketchUp doesn't actually have true smooth curves in it at all, what SketchUp calls a curve is actually made up of a bunch of little line segments. A "weld" type operation in a polygon modeler is a bit different than MoI's Join function. MoI's Join is somewhat more like making a group, but kind of a special group where the pieces know that they are connected together either end-to-end for a curve or edge-to-edge for surfaces.
Well, 3DS Max and gMax are polygon based modelers, so this was possibly referring to needing to have polygons welded together so that the triangles that make up a surface share a common vertex point which then can make it easier for program code to find adjacent polygons to traverse them.
The equivalent kind of "traversability" in a NURBS based program is having 2 surfaces be joined together so that they have a shared common edge rather than being 2 completely separate surfaces that just happened to be nearby one another.
So that edge that you were worried about previously was not a problem in this sense because it was a joined edge between 2 surfaces.
The geometry in 3DS Max and Gmax is made up of triangle meshes, so it's actually chock full of edges everywhere, it just won't display them all the time unless you are in wireframe mode. So I doubt that the CNC Toolkit thing is actually sensitive to just any edge or else it wouldn't be able to handle more than just 1 triangle at a time, that warning was most likely about an edge where it could not find another adjacent polygon that was hooked into the same vertices as the current one.
You could actually find a similar issue in there, but just to reiterate - the issue is probably going to be if you have just totally separate unjoined surfaces as compared to surfaces that are joined together and share a common edge (making a connected skin).
4123.32 In reply to 4123.30
Hi Mr. Burr,
thanks for your time and yes sometimes, maybe more then I would like, I have crazy ideas. This 5 axis CNC idea is probably one of them especially that I would need to spend countless hours to learn a lot of stuff on own. My wife suggested this simple idea of doing something simpler we could do as a team just as we do already for quite a few things. We are close to retirement time and I think this idea of doing even more stuff together is just great.
But I also like to keep my brain busy sort of speak so I'll probably buy MOI even if only to do just that. I might also build myself a small 3 or 4 axis CNC for the same reason.
Regards,
Felix
4123.33 In reply to 4123.31
Michael,
as I said in the beginning, I'm a newbie at all this NURBS stuff and same goes for 3D design. I'm old enough that when I started drawing stuff it was on paper, my first computer was an Apple II and at that time I was in the minority, of course today it's the other way around.
As I said earlier, I'll probably buy MOI even if it's just for the fun of learning new stuff. Unfortunately for you guys here, I'll probably have few more silly questions coming by this forum. I just hope they'll few and far apart.
Thanks again,
Felix
4123.34 In reply to 4123.33
today I tried something easier, just practice stuff and fun, nothing to fancy. Then I decided to render the mirrors just to see, so I exported them to obj which loads directly in Kerkythea and tried a few thing but without success I'm afraid. I assume it as to do with UV mapping or most likely me, I'm afraid I'm newbie at that as well. I though of asking you guys for suggestions on rendering apps that are as easy to use as MOI and as cheap as possible that would make a good companion for MOI and whatever you can think of that I could read to learn as much as possible on rendering?
Thanks in advance,
Felix
4123.35 In reply to 4123.34
Hi Felix, some links to discussions on renderers here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4098.3
There are a few different suggestions in those threads that you could try.
Often times renderers are not particularly focused on being easy to use as a big priority though.
4123.36 In reply to 4123.35
< Often times renderers are not particularly focused on being easy to use as a big priority though.
Except some like Podium for Sketchup ;) http://www.suplugins.com/
4123.37 In reply to 4123.36
Michael, Pilou,
thanks to both of you. Lots and lots of info to digest but I'm not sure I'll live long enough to just scratch the surface of the rendering world. It's like the United Nation where there are a lot of different languages and cultures but no indications where to find the translators.
I came across this video http://www.vimeo.com/4810249 for example. It's not bad per say, some may even say it's excellent but it's almost useless for total newbies. It's what I would call a recipe type document, do this, do that and by the way you can do this and that as well. You see I was a teacher in another life and I know that people don't learn much from document like this because it looks so very easy for someone who is already an expert using these 3 apps together. But for a newbie, after downloading and installing Blender and Lux he or she basically hits a cement wall 4 foot thick. As you well know Michael, I don't think anyone could say that one can learn to just navigate with some ease through Blender UI in a few minutes, maybe not even in a couple of hours. More or less, the same could be said for Lux, MOI and any other apps for that matter.
It's true that one of if not the most efficient method of learning is by <doing> stuff yourself especially when you have a project that gives you plenty of motivation. But that's forgetting the main ingredient, basic knowledge of the context or some basic theoretical knowledge as some might say. Say your goal in life is to become a fisherman but you're a total newbie at this and you come across a video tut that basically tells you go get a boat and a net, throw the net at sea, drag it for a while and bring it in, all this while the video shows the net coming in filled with fish. Sound and looks easy but unless you are a very very lucky guy I would bet a week pay that you'll have a nice day at sea but few if any fish to show for your work. One would think it's easy to figure out what's missing in my example but it's not, especially for an expert kind of guy.
The basic idea behind all this is that when someone knows how to do something it always looks easy to a newbie and when one tries it on his own it's not long before one realize the learning curve is more or less steep depending on one contextual prior knowledge of the task.
Though some may find this an interesting or possibly a boring topic. It made me realize that I need to be a bit more specific about what I'm looking for, especially that at this time, I'm a newbie at 3D design and rendering. Basically, I'm looking for reference material (books and or papers) that are use currently as teaching material in university level programs on 3D design and or whatever programs where rendering photo realistic scene is a prerequisite or that is part of the main program. I'm sure such material exist and it's plentiful and that's the problem and the reason I ask you all, knowing that some of you still have those books from college or universities as we call them here. I can read in both English and French just in case someone think of a french book.
Felix
4123.38 In reply to 4123.37
Hi Felix ...
The best way to get started in MoI is to do the tutorials ... as many as you can do.
As you said, the way to learn is by doing. Some things can be done by just jumping in ... others need some instruction.
My advice would be to do the MoI tutorials first and then try modeling some simple things on your own. You don't have to learn all a program has to offer ... just the things you need to complete the project you are currently working on ... make the next project a little more complex and learn a couple of more things the program will do.
I say this as an old timer (much older than you) who has become fairly proficient with many programs over the years ... but not a true expert in any. I have managed this a step at a time without ever trying to get a university equivalent in any of them.
I make a living as an architectural designer. MoI or Rhino or any of the others will provide the tools for a wide, wide range of uses ... more than I will ever need. So learn the basics you need and grow from there.
Start with MoI and an inexpensive renderer (Like Sim Labs Composer) and enjoy the process. You could spend a fortune on great software and get overwhelmed with complexity.
Enjoy,
eric
4123.39 In reply to 4123.37
Hi Felix, yes definitely a lot of 3D programs can be quite complex. Blender has a lot of functionality but a somewhat unusual UI, and a lot of times just having a lot of functionality available can actually be detrimental to a beginning user because it's easy to just get overwhelmed being submerged in a ton of stuff that is all unfamiliar.
So if you're looking for something that's easy to use, Blender is probably not going to be the right fit for you despite the price being great (free).
Like eric mentions, SimLab Composer could be a good fit for you, give it a try here:
http://www.simlab-soft.com/
Export from MoI using OBJ format and set "Output = Quads & Triangles" and then import that .obj file into SimLab to render it.
re: videos - have you watched the MoI tutorial videos from here yet? :
http://moi3d.com/2.0/docs/tutorials.htm
I have made some special effort with those to make them friendly to beginners, they go along slowly and with additional explanation at each step.
4123.40 In reply to 4123.37
Hi Felix, also re:
I'm not so sure that this kind of material is actually very easy to find...
One problem is that university programs that focus a lot of effort on 3D design also tend to revolve around 3D programs that incorporate a whole lot of functions in them, including things like animation and motion dynamics, etc... Such programs that do a lot of things are just by their very nature more complex to use so they're probably not the right choice for you despite having a lot of reference material on them.
The renderer that Pilou mentioned, Podium, runs inside of SketchUp which you're already familiar with so that might work well for you, I think there is a trial version you can get from here: http://www.suplugins.com/supodium-v2.php
Giving both Podium and SimLab Composer a try to see if they will work for you is probably a good start.
4123.41 In reply to 4123.38
Eric,
I've seen many MOI tutorials, those of Michael I would think and some from Pilou and I also went through the MOI help files to get an idea of what can be done with it. All this before I even download MOI.
Your the perfect example of what I tried to say earlier, you have an architectural design background and years of experience at it using various tools or apps if you prefer. You probably started drawing on paper as I did and progress to using various software when they became available. But being proficient at using MOI or any other app doesn't necessarily make you a DESIGNER, just as having a boat and a net doesn't make you a fisherman you would also need to learn quite a few things as well, for example knowledge of navigation and some knowledge about fish might be very helpful.
A little clarification about my (very limited) drawing knowledge, I followed a course (45 hours) about 30 years ago on descriptive geometry. On my own, I learn to use a couple 2D cad programs that I used very infrequently over these past 30 years. It's just about 1 year ago that I started using Sketchup because it's easier for my client to visualize things that looks almost like real 3D objects then 2D drawing. About 3 months ago, I got this (crazy) idea of creating a virtual showroom to present models of furniture pieces that I would like to build one day either for my own needs or for potential clients. Thus my very recent interest for 3D design software and rendering. The CNC idea came to me about a year ago as well.
Even before I started thinking of 3D modeling and rendering pieces of furniture, I investigated this idea, what makes a particular design more attractive then others? For my line of work this could translate to: how do student learn? In other words, for me just being capable of drawing things will always be insufficient, it's like something inside me was making me insatiable for more, a lot more.
Felix
4123.42 In reply to 4123.41
Hi Felix ..
Yes, good tools do not make a good designer. Good designers are born with a sense of proportion that gets honed over a lifetime of experience and, hopefully, some training and critiques by other good designers. If one wants to design furniture it is important to study good examples in depth to get a sense of what is grace and beauty and what is not. The same with buildings or any other art form.
There are many bad examples of both furniture and architecture out there, too. Sometimes designed by well trained and often famous people.
That said, tools are important. When I drew by hand my clients would get one perspective view of their project or maybe only a flat 2D sketch if the project was small. Now they get 3d views from every angle and detailing I could never take the time for in the past. What they see is what they get so when it is built they don't say 'Oh, I didn't know it was going to look like that!'
At the same time, one does not need a multi-thousand dollar program to create good images. Sketchup (even the free version) is good, though I personally don't enjoy using it. MoI is superb for my 3D work and there are a number of free CAD programs that produce good 2D drafting (Draftsight is one that works well).
I was an early user of AutoCad (at one point a firm I was a partner in used 12 stations) and spent thousands of dollars over time. But it got bloated and cumbersome and more and more expensive.
So my advice is keep your tools simple and inexpensive, make them an extension of yourself, and keep them sharp.
cheers,
eric
4123.43 In reply to 4123.42
Eric,
I basically agree with every word you wrote. I don't pretend or dream of being or becoming a furniture designer any time soon if ever, I'm much to old for that.
At this time, I'm only trying to "reproduce" pieces of furniture I like, mostly period pieces from our past history here in Quebec adding a few details of my own when possible and I also try to use as much as possible the Golden ratio and Fibonacci numbers when sizing pieces to fit in modern houses.
>That said, tools are important. When I drew by hand my clients would get one perspective view of their project or maybe >only a flat 2D sketch if the project was small. Now they get 3d views from every angle and detailing I could never take the >time for in the past. What they see is what they get so when it is built they don't say 'Oh, I didn't know it was going to >look like that!'
My reasons to "draw" 3D models and rendering them are the same as yours, I simply don't want to ear stuff like you mention above. I also think it could be useful at some point to be able to present the same object but with a few different finishes. You mention also that you don't want to spent more time "drawing" then necessary on small project. Same here, especially that pieces of furniture are always a small project.
I don't think I'll have much difficulties learning MOI but it seems to be another story with rendering. I tried a few things via Sketchup and Kerkythea since I know a little bit about them but the results are not so great to say the least. But I wasn't expecting much to begin with, my little previous experience with this route wasn't satisfactory either. I think Ill have a long road ahead.
Regards,
Felix
4123.44 In reply to 4123.40
Michael,
thanks for all this info. I think I have lots of work and study ahead but that's my problem.
I noticed when I export to skp that Moi solid turn into individual entities as SU calls them and when I use obj instead, all solids turn into groups in SU and even the name I used in MOI are present, I'm I missing something on the skp export?
I also tried to export to blender using lwo format and every thing seems fine.
Since my work basically always involve pieces of wood and that I use only 2 types of finish, either a varnish or somekind of "faux fini" using paint on top of varnish. From the little I know, wood seems to be quite difficult to render realistically, the grain pattern causes each faces to look differently, one can add to this, random things like knots, defects or machined edge and carvings. Varnish and paint also present there own set of characteristics that are more or less difficult to render especially when there applied using a brush. I wonder if there exist someway to apply a grain pattern to an object representing a piece of wood such that it look like a real solid piece of wood. I wonder also if any program would be better at this then others even if it's more or less difficult to use and learn?
Don't worry, this may exist only in the miracle department and nobody I know of knows where it is.
edit: I think I've found the miracle department! The procedural wood texture in Blender seems to fit the bill, the docs says:
"Wood is a procedural, which means that each 3D coordinate can be translated directly
into a color or a value. These types of textures are 'real' 3D. By that we mean that
they fit together perfectly at the edges and continue to look like what they are meant
to look like even when they are cut; as if a block of wood had really been cut in two."
Sounds promising...
Felix
EDITED: 27 Mar 2011 by FELIX
4123.45 In reply to 4123.44
With wood textures (in a polygonal modeller, which you will probably have to use to render) it is usually necessary to UV map each mesh object. This map tells the renderer how to lay out the texture on the surface of the object. The reason it is necessary is that you need to control which way the grain flows and which parts need to show end grain features. Plain mapping, like cubic or spherical often don't work properly, particularly where the piece is curved.
4123.46 In reply to 4123.44
Hi Felix,
Which version of SketchUp are you using? Over here if I export a solid like a box for example, when I open it in SketchUp v7 it's a connected set of objects, for example triple clicking on one face in the box selects the entire box.
Objects in SketchUp are made up of multiple smaller entities though, like a box in SketchUp is made up of 18 individual smaller entities - 6 faces and 12 edges, that's just fundamentally how SketchUp functions. But when you export a solid from MoI these various entities are welded together to share vertices in common with each other, that's why you can triple click it in SketchUp to select it all as one object. That's the same kind of structure as if you were to just draw the box directly in SketchUp.
Are you seeing something different than that, or are you maybe more used to working with a group object in SketchUp? Currently MoI just exports regular geometry and does not create group objects, but in the future I'll probably be changing the SKP export to make groups instead.
Some of the advantages to using SKP export rather than OBJ is that with MoI's SKP export you'll be able to get planar faces in MoI to come through as simple planes in SketchUp, including ones that have internal holes in them. OBJ format does not have any way to represent a polygon that has a hole inside of it, so if you use OBJ planes with holes in them will get split in half. Also the SKP export from MoI makes sure to set all the edge flags for smooth surfaces to correspond to the original surface structure in MoI, whereas OBJ import into SKP is probably going to use things like the angle between polygon faces to decide whether to make an edge to be hidden and smooth or not and that can sometimes make the wrong choice for that which can leave some edges visible in what was originally a smooth single surface in MoI.
Show messages:  1-6  7-26  27-46  47-63
