Feature suggestions
 1-14  …  35-54  55-74  75-94  95-114  115-134  …  195-214
412.75 In reply to 412.74
> Is not possible to have an automatic drawing of extern curves (and
> internal if another transparent aera inside) of the Object directly in Moi?
You mean making MoI automatically trace the contours of your bitmap to generate curves?
Unfortunately that's pretty difficult to do well... It would take quite a long time to come up with something. Maybe someday.
Once there is AI format support you should be able to use other existing tracing software though, I think that there are a few different things out there for automatic tracing for 2D illustration programs.
-Michael
412.76 In reply to 412.75
< You mean making MoI automatically trace the contours of your bitmap to generate curves?
Yes :)
So yes we can use exten vectorized prog as soon as ai format exist :)
A simple curves "Formula Creator" (2D or 3D)
maybe not so sophisticated than this free one :) http://k3dsurf.sourceforge.net/
but something for sinusoïd, helicoïd, ...etc http://en.wikipedia.org/wiki/List_of_curves
412.78 In reply to 412.68
> Could it be possible to leave object(s) selected after joining or
> separating them using Join/Separate command?
This one is now set up for the next beta.
412.79
Id like to see the icons for adjusting the view at the bottom of the perspective viewport removed. I find the mouse commands for changing view very easy and convenient to work with, and the icons only take up space and get in the way.
412.80 In reply to 412.79
HI Arquebus - you can (nearly) completely remove them by deleting this UI file from your installation:
C:\Program Files\MoI beta Mar-9-2007\ui\ViewControls.htm
Right now there will still be a tiny rectangle left over after removing that, but I will see if I can tune up the next beta so that if you remove that UI file there won't be anything down there at all.
However, there are 2 important controls on that panel for zoom area and reset in addition to zoom/pan/rotate.
Even if you use the mouse commands for zoom/pan/rotate, it is still quite useful to have these other 2 commands available.
about the curve from a "formula inbox" ? :)
412.82 In reply to 412.81
Hi Pilou, it would be fun to do it, but it would take quite a lot of time to do the UI and parsing work.
It will probably be quite a while before I can find enough time to work on something like that...
There are just too many other basic things to do first. For example I could probably do a formula inbox for version 2.0, but only if I canceled work on object properties and object organization tools...
If you can figure out some way for me to get more than 24 hours in one day, then I could do it sooner! :)
412.83 In reply to 412.82
It's not possible to have just a list of generic "pre calculated" curves?
And we can modifiy it on the screen with the normal function, Scale, etc...
So no need to implement a complex formula inbox :)
Sorry for the 24 hours, I can't make nothing, I am not the creator of this curious world :)
412.84 In reply to 412.83
But do you really need a command for this? From what you're describing there just importing an .igs or .3dm file with those curves in it would work the same way.
One thing you might try: http://www.graphcalc.com/index.shtml I saw some people mention it can export to DXF. Maybe it is possible to convert to MoI through Amapi. If you have a few that you want to convert, you can post them here and I can convert them from DXF for you using Rhino too...
412.85 In reply to 412.84
< But do you really need a command for this?
Not a command :) Just a little "library"
Of course any curves or surfaces can be imported in moi
just seems more cozy to draw all inside Moi :)
Sure I can draw easily a sinusoid with just 2 arcs and arraydir :)
EDITED: 22 Mar 2007 by PILOU
412.86 In reply to 412.85
I guess it seems like a repository of files is pretty much the same thing as a library to me...
But this isn't a very accurate sine curve - a "real" sine curve doesn't have the shape of an arc. Which is kind of funny since it is the graph of an arc as it swings around...
412.87 In reply to 412.86
an arc of an half circle of course
Ps For the progs : ) http://forum.jotero.com/viewforum.php?f=24
K3Dsurf seems the best It has an OBJ export
Rest to found a transform obj -->nurbs That is another story :)
412.88 In reply to 412.87
> an arc of an half circle of course :)
Yup, but although it is similar, it is not the correct shape. A sine curve is kind of more of a lump, it doesn't have the exact shape of an arc.
> Rest to found a transform obj -->nurbs :)
This may be a difficult transform. But didn't Amapi do something for this when exporting polygons to IGES? I thought that some wireframe line curves came through. So that is one possibility.
But it looks like K3Dsurf only does surfaces and not curves - for doing curves possibly that other one will work.
412.89 In reply to 412.88
Half circle and Scaled on 1 or 2 directions successively with subtil axes of deformations :)
PS Yes Amapi has Iges , and Rhino has a plug named Smurf I believe
412.90 In reply to 412.89
And you can draw in k3Dsurf curves just take the good parameters for have a slicy slice :)
And export it as OBJ : that works (Button is named "Edit" but It's also save ! :)
Sure it's a pity to not profit of the Surfaces :) :I don't want to be the triangles of this curve :D
412.91
I'm just wondering if it's at all possible to have Height & Width with the Draw Curve > Eclipse > Centre.
So that it would work like you've already got with the Draw Curve > Rectangle > Centre.
From a Jewellers perspective, this would make life much easier than having to count the grid spaces when creating an oval.
regards Colin
412.92 In reply to 412.91
Hi Colin, I'll try to add that in.
In the meantime, you can use "Distance constraint" to help out right now.
To do this, just type in your distance and hit enter (you can also click on the "d" text box down on the bottom bar).
Doing that activates distance constraint which forces the point that is being picked to be that distance away from the base point. So for Ellipse/Center that would be 1/2 the width since the base point is the ellipse center point in that case. So you would actually need to enter in half of your desired full width for this one. Still easier than counting grid spaces though.
But I'll try to add in a width/height like rectangle so you won't have to divide in half.
412.93 In reply to 412.92
Thanks for that advice, I'll give it a try.
So far I've been getting around it by creating a Rectangle the exact size I want.
Then I just select the Eclipse & have it snap to that Rectangle edges.
Delete the Rectangle & continue from there.
regards Colin
412.94 In reply to 412.93
Hi Colin, I've added a Width and Height control for the ellipse command for the next beta. You still need to click 3 points to finish the ellipse even if you enter a width and height, because those points define the orientation of the ellipse. In 2D the 3rd point doesn't really do anything if you have entered a height, but in 3D you can switch to the front viewport (or track along a z line in the 3D view) to orient the ellipse vertically.
This was the last thing I wanted to fix up for this beta so it is almost ready.
Show messages:  1-14  15-34  35-54  55-74  75-94  95-114  115-134  135-154  …  195-214
