Feature suggestions
 1-4  5-24  25-44  45-64  65-84  …  205-214
412.25
Woaw !
Boolean on curves was one of my requests ! I didn't expect to see it in MoI before V.2... Can't wait for the next beta...
Thanks Michael !
MoI version 1 and ZBrush 3 released next spring ! It's gonna be crazy !!!! ;-))
412.26 In reply to 412.25
You mean this Spring for Zbrush 3... ;)
412.27 In reply to 412.25
Ok, another Boolean enhancement for the next beta: Auto-extrude.
This allows planar curves to be used in the boolean as either a cutter for Boolean Difference, or as an entry into Boolean Intersection.
This is a convenience factor which automatically handles extruding the planar curves through the objects behind the scenes.
So for example given this setup with the curves floating in front of the sphere:
In the next beta you will be able to do boolean difference to do this:
Or boolean intersection to get the reverse:
I think just one more area to tune-up before Booleans are all finished for V1...
412.28
Wow! Exactly what I need! :D
412.29 In reply to 412.26
I mean the one coming after this winter... ;-)))
I'm just wondering how the new tools in ZB3 (matcap and some other things I've seen on the video) will ease the process of texturing objects created in other applications like MoI...
Maybe Michael should release V.1 on the 15th of May as well. I would take a week holidays then... ;-)
@ Michael : Auto-extrude looks great !
412.30 In reply to 412.29
Ok, just finished another boolean tune-up for the next beta - Boolean difference now works well when using surfaces instead of only solids.
This combined with auto-extrude means that this is now possible - given this setup:
Doing a boolean difference of the box with curve as a subtraction gives this (pieces moved to illustrate):
Where each piece is a solid. Here's another example - the results are all solids:
So quite a bit of boolean stuff for the next beta coming...
412.31
Very cool stuff!
412.32
I think this spring I will get a new release of all the apps I use!
AutoCAD, Revit, Maxwell, MoI, etc...
***There is a better way to do things... Just find your Moment of Inspiration***
412.33 In reply to 412.27
What happens when group of curves will be inside of solid or intersect the one?
Petr
412.34 In reply to 412.32
Hi JTB, AutoCAD is released each spring... I think it is rather embarrassing then worthwile... -Petr
412.35 In reply to 412.33
Hi Petr, I may need an image of this to be certain that I understand your question.
But if I understand correctly, it doesn't matter where the curves are located, they can be anywhere along their plane normal and have the same effect.
This is because the solid doesn't interact with the curves directly - instead imagine that the curves are
moved along their plane normal to be placed just a little bit outside the bounding box of the solid (or surface), then extruded so that they push through to a little bit more than the other side of the bounding box of the solid.
This produces the same extrusion part no matter where the curves are placed along that normal direction.
Then the solid actually interacts with that extrusion.
I've now finished Union now to work properly with surfaces.
All that is not in the beta of the 26 / 2 feb 2007?
412.37 In reply to 412.36
Hi Pilou, nope - all this new boolean stuff will be for the next beta which should be ready pretty soon.
412.38 In reply to 412.37
Just an update - I'm trying to get the new curve boolean stuff to work on open curves as well instead of only closed curves. I'm making progress but it is taking a while, maybe a day or so longer before the new beta is ready with all this new boolean stuff.
412.39
Feature Suggestion: Min/Max Range Values for Offset & Shell commands
If you're not particularly paying attention to the scale of your model, then you don't know where begin when plugging in values for "Offset" and "Shell"... I often have to try several values just to get one that successfully displays a result on the screen.
Would it be possible for MoI to display the Upper and Lower Limits of possible offsets by default, or perhaps provide a "Calculate Min/Max" Offset button? (Obviously you would need to cap the MIN/MAX values well before infinity for very simple surfaces that have virtually nothing limiting how far they can go.)
Also, if MIN / MAX values are present, perhaps a range "slider" could be provided at the bottom of the keypad so one can simply slide between the values to evaluate different distances or thicknesses. With a range slider, you would probably need to provide a little "Calculate" button so that MoI didn't try to calculate the offset or shell operation each time you nudged the slider...)
412.40 In reply to 412.39
Hi Justin, I guess this would involve a lot of different calculations, some on detecting the curvature of surfaces, and others trying to analyze the interference between different adjacent surfaces.
Unfortunately these calculations are really complex, it would be really hard to actually implement this, even harder than doing the shelling operation itself...
But I do want to figure out some way to improve this in the future though.
In the meantime, there is an alternate method to entering a numeric distance - you can pick 2 points in a viewport, and the distance between those points will be used. This can help adapt to the scale of your object for example by picking the 2 points snapped on to a piece of your object...
412.41 In reply to 412.40
That's very helpful! I didn't know you could specify a distance for an offset or shell that way... Here's another idea based on whay you have going already: simply let the user set a own Min/Max slider on the fly. Instead of the two clicks defining a set distance which is applied immediately, the two clicks define the Min (always 0) and the Max. Then as one slides between the two points, the offset, shell or fillet shrinks and grows.
Anyway, just a thought. Being able to pick a distance in the viewport definitely gets one in the ballpark for finer tuning with the keypad. Thanks!
412.42 In reply to 412.41
Hi Justin - that same thing (pick 2 points for distance) also works for fillet and chamfer by the way.
Re: Slider - I've had a couple of thoughts along this same line. I was thinking that once you have a distance (I guess I could default to 1.0 instead of no default, especially now that you can cancel and update parameters dynamically) I could put a couple of grips on the model, along some surface normal lines.
If you grabbed on one of those grips you could drag it and it would be another way of tweaking the distance - the current "distance between any 2 points" method would still work if you clicked somewhere not next to one of those grips.
But it is going to be a while before I'll be able to experiment with this.
412.43 In reply to 412.38
Curve booleans with open curves have proved to be pretty challenging, but I'm getting there.. Just finished difference. (note that this is for the next beta, not the current one).
Given this initial setup, with a grid of simple line segments and a closed region:
Doing a boolean difference with lines difference closed region gives this:
Basically just automatic trimming of the lines.
But somewhat more interesting is the closed region difference the lines:
This takes the lines and sort of imprints them into the closed region to form a bunch of new diced up closed regions (shown slightly separated for illustration).
Still have a some work left to do on the other operators for open curves though.
412.44 In reply to 412.43
Must be a little headache for code that :)
Some aeras have some priority to other?
Order of selection make some differrence?
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  …  205-214
