Feature suggestions
 1-7  …  168-187  188-207  208-214
412.208 In reply to 412.207
Sure :)
we can't have more than 2 numbers visible after the decimal point on the tool barre bottom?
412.209 In reply to 412.208
> we can't have more than 2 numbers visible after the decimal point on the tool barre?
You can have more - go to Options and set "Decimal places to display" to a different number, just the default is 2.
But several things such as intersections are calculated to a precision of 0.001 units. So unless you stay away from operations that involve tolerance (Boolean, Intersections, Fillets, Offsets, ...), it probably won't do you too much good to look at many more decimal points in the UI.
You generally need to pick a proper unit system and scale for your object such 0.001 units is smaller than the smallest detail that you want to represent, and your object should generally be less than 5000 units in overall size, otherwise there will tend to be problems in areas that require complex mathematical calculations such as Booleans and Fillets.
412.210 In reply to 412.209
thx I had seen before but don't refind it : Syndrome of the The Purloined Letter. by. Edgar Allan Poe :D
So If I have good understand
With a "Kilometer" unit "best" maximum precision can be the meter? :)
You say 5000 units max so 2500 "grid section" or admit 5000 "grid section"?
because in previous post you say -5000,+5000
so 2500 kms or 5000 kms with "snap size" 0.001:it is yet not so bad!
EDITED: 14 May 2007 by PILOU
412.211 In reply to 412.210
Hi Pilou, keep in mind these are just general guidelines to help avoid problems with commands that involve more sensitive calculations. Some commands are less sensitive to it than others. Booleans, Fillets, and Shelling tend to be the most sensitive.
Yeah, I think that would probably be a pretty good limit.
412.212 In reply to 412.211
< Yeah, I think that would probably be a pretty good limit.
So a square surface of 10 000 kms with a precison of meters
(with Snap Size 0.001 and 3 decimal point in the barre bottom---> (or a precision of 1/ 10 000 000 with no unity):)
It's not so bad!)
412.213 In reply to 412.212
Hmmm, setting snap size to 0.001 might not work very well. Since that is the fitting tolerance, basically you don't want to create curvy details that are at that size - that's sort of more the lower limit.
Setting snap size to 0.001 might encourage you to draw details that are around that same size... So something like 0.01 for the lowest snap size would probably be better.
It's even better yet to create objects that are not so near to these limits at all... I almost didn't want to include kilometers or miles as units at all because they kind of encourage pushing things to larger or smaller numeric values like you're talking about.
412.214 In reply to 412.213
Of course!
But you can if you want insert precise measures (even in kilometers with the 3 décimal in the tool barre box or read it under the mouse movement! :)
Not obliged but a possibility :)
Sure at this scale 0.001 precision is an hard work on the Mouse wheel :D
And "snapping" is only good on the helpers and curve's points not on the grid itself!
Show messages:  1-7  …  148-167  168-187  188-207  208-214
