Feature suggestions
 1-20  21-40  41-60  …  201-214
412.1
Michael, how do you feel about feature suggestions?
I can imagine that you have a large 'To do' list. So I don't want to be pestering you with suggestions for features when you're busy with just getting MoI into a 1.0 state.
Should I come back when you're at version 2.0? :)
EDITED: 9 May 2020 by FINEMA
412.2 In reply to 412.1
No, please don't wait, go ahead and suggest away.
I like to see suggestions and feature requests sooner rather than later - it helps me when I am able to see stuff like common patterns emerging.
Of course, I'm sure that some will take a while to implement... :)
EDITED: 28 Jul 2018 by FINEMA
412.3 In reply to 412.1
Hi wibble:
For fortune we have Michael to the front of this project and I can tell you that it will always be attentive to answer all our doubts and to accept suggestions and to correct errors, for what I always suggest you to be willing to send your doubts and they will always be answered.
greetings
412.4
Michale any chance that you make some kind od a shortcut editor?
I know there is a workaround, but having this for the final V1 is a must have!
412.5
Also make volume options or I think its called make Mainfold...with history on this is a killer!
412.6 In reply to 412.5
Hi Kreten, do you mean command for making solid from individual surfaces - see http://www.smlib.com/smlib.html -Petr
412.7
Hey tyglik,
The merge operator from that page you linked to is exactly how the CAD package CATIA can create solids. If that was implemented into MoI....OHHHH BOY!
412.8 In reply to 412.6
Egsaclty that one!
Imagine this in combination with history to edit final surface shape!
WoW!
412.9 In reply to 412.4
Yeah, I probably need to do this pretty soon along with a re-organization of the options dialog.
412.10 In reply to 412.5
Re: Make manifold / merge
This one seems like a bit of an odd operation to me, since it involves creating a model with all sorts of excess pieces sticking out in all directions.
It just doesn't seem like a very natural approach, it's just a little easier to work on a few surfaces at a time and trim smaller pieces instead of having everything all sticking out everywhere.
Also right now it is possible to get the same result by using Trim and Join - select all the surfaces, run Trim, push Done instead of picking any other cutting objects (because in this case the objects being cut are also the cutters), and then hit done to leave all the pieces - select the excess pieces and delete, and select the remaining pieces and join and you've got that same result.
I guess I could add the Merge / Make manifold operation as a special case of boolean intersection. I suppose if you select only surfaces and no solids, and then run boolean intersection it could do this merge operation, would that make sense?
412.11 In reply to 412.10
I think yes:-)
412.12 In reply to 412.10
I tried out a demo of PowerShape which uses manifold surfacing and it seems a bit
hit or miss...I suppose if you want to quickly sketch something out in 3D for visualization
and don't care too much if the shape and size is exactly on target, then it could be useful.
Just my $.02
-Jesse
412.13 In reply to 412.11
> I think yes:-)
It looks like this will be possible for the next beta, the way I've got it right now is if you select all the objects to merge on the first boolean intersection prompt, and then push "done" without selecting anything for the second set, it will do this merge operation instead of the regular intersection.
This also allows it to work with solids, which I think seems pretty useful because it allows for this in one operation now:
This type of merge with a solid and a surface allows you to get 2 solids in one easy operation. I may end up duplicating some of this behavior inside of boolean difference as well, when differencing solids with surfaces.
I think I'm going to try a couple other boolean tuneups now as well.
412.14 In reply to 412.13
Here's a sneak peek at some other in progress boolean work...
412.15 In reply to 412.13
It looks like _BooleanSplit in Rhino(?).
Anyway, boolean operations between solids and (poly)surface(s) would be useful.
Petr
412.16 In reply to 412.14
aaaaaaaaaaaaaaaaaaaaaaaaaaaĆ”......... Boolean curves! Amazing!
412.17
/me drools. :D
MfG
sk2k
412.18
Boolean curves looks really nice Michael! I can already think of ways to use it :)
I have a small request regarding selection.
Is it possible to implement "select edge loops"? I've attached a couple of screenshots to show what I mean. If you select an edge of an object and be able to use a command that will it enable a selection of all of the edges in a loop. Not select all edges but all edges on a single face that are connected.
Free Image Hosting at www.ImageShack.us
412.19 In reply to 412.18
Hi Richard, I definitely want to add some kind of edge chain selection helpers in the future, but it doesn't look like they're going to happen for V1. I expect to have a set of selection helpers like this for V2.
412.20 In reply to 412.16
Yup curve booleans are in for the next beta!
Here's another example:
Original:
Boolean difference:
Boolean union:
Boolean intersection:
There is also a merge operation which like the previously mentioned merge is invoked by doing an intersection with only one set and pushing "Done" instead of selecting a second set - this will cut everything into piece and generate all the closed loops. So in this case the result looks the same as the original, except it is all split into little pieces.
The way these work is if you select only planar, closed curves that are all on the same plane, then the boolean tools will do a curve boolean.
It seems to be working really well, the only complication is with Union in some places - since everything is all selected all in a single shot for union there are some times when it can't properly tell when a shape completely contained inside another is supposed to be a hole or a solid shape.
The really cool thing is this is yet another instance of making the existing tools more powerful without adding any extra UI!
Looks like I will be able to wrap curve booleans up tonight and try a couple other boolean enhancements tomorrow...
Show messages:  1-20  21-40  41-60  61-80  …  201-214
