change cornerpoints to smooth-points?
4097.1
Is it somehow possible to change a corner point (endpoint) to a soft midpoint?
when i connect 2 lines and join them, the connectionpoint is still a cornerpoint. can i change this connected point to get a smoother line?
the "rebuild"-command don't work/fix this.
4097.2 In reply to 4097.1
Hi BlackBird, currently the way to do this is to insert a new point using Edit > Add pt, next to the one that you want to change and give the new inserted point the style (either corner or smooth) that you want to end up with. Then delete the old one.
Or you can do it the reverse way - delete the corner point and then insert a new smooth point in that area.
In the future I do want to make a way to change the style (whether corner or smooth) of a selected point but currently the above ways are the way to do it.
- MIchael
4097.3 In reply to 4097.2
Ok, thanks for the answer and i try it the way you told.
