Converting 3DS + OBJ to MoI 3DM using "Mesh To Solid"
409.1
The other night I ran across a utility 3D file conversion program from SYCODE called "Mesh To Solid." This is NOT the plugin versions, it is a standalone app. Downloadable trial online, and priced at $195 this immediately drew my attention.
Details and Functional Demo online at the following URL:
http://www.sycode.com/products/mesh_to_solid/index.htm
Related description from their site:
"Mesh To Solid can read mesh objects from the following file formats:
Rhinoceros files (*.3dm)
3D Studio files (*.3ds)
Stereolithography files (*.stl)
Wavefront files (*.obj)"
"Mesh To Solid saves solid data in the following file formats:
ACIS files (*.sat)
Rhinoceros files (*.3dm)"
I have downloaded the 10 day/10 use Trial Demo but can barely find the time to write this post let alone test that! So, my question to you all is:
Has anyone here ALREADY tried SYCODE's standalone "Mesh To Solid" for importing meshes into MoI's 3dm format with any degree of success?
- 3dvisuals dude
EDITED: 9 May 2020 by FINEMA
I know this one Smurf
Smurf is a Rhino plug-in that allows for the interactive conversion of polygonal meshes to NURBS surface patches.
http://www2.rhino3d.com/resources/display.asp?language=&listing=93
(not trying )
I don't know if this one can works directly for Moi?
409.3 In reply to 409.1
Thank you for the link, but unfortunately it is quite expensive for me right now. I hope to one day get mesh objects into MoI, specifically for reference purposes. For example, I have a character I am sculpting in Mudbox, but I would love to create his armor in MoI using his mesh as a reference.
409.4 In reply to 409.3
It may be possible to use something to convert the edges of a mesh like that into line segments that are then saved out as curves to a .3dm or .iges file.... MoI could then read in those lines and they could be used as a guide.
This could work for example by using ExtractMeshEdges in Rhino - I think there is some way to do it in Amapi as well.
409.5 In reply to 409.4
Thank you, I will look into these options.
