moi idl file
All  1-5  6-7
4073.6 In reply to 4073.5
Hi Burr, well the only thing that oleview does for you is to give you a way to extract the moi.idl file that is embedded inside of moi_lib.dll .
If you already have moi.idl , then there is no need to use oleview for anything at all, you would just be getting at the same file that you already have.
As far as reading moi.idl itself - it's just a text file so you can look at it with any text editor program, you don't need any special viewer program just to look at the .idl file.
You'll see various interfaces defined within the moi.idl file, and different properties and methods will be listed within each interface.
But Dave's web pages have this same information presented in a nicer way so you probably just want to look over there instead anyway.
4073.7 In reply to 4073.6
I might mention that the information on my web page is, in some ways, a superset of the information in the moi.idl file. I wrote a script that extracts all of the API information from the .idl file and then, by hand, annotated many of the properties, methods and arguments with as much detailed information about the interface as I could muster by eyeballing the API and, in some cases, experimenting with more obscure interfaces via test scripts.
The extraction script also performs "deltas" between successive versions of the moi.idl file, so new API elements will appear in the web page automatically (although any descriptive information will need to be added by hand).
If anyone wants to contribute additional API descriptions for inclusion in the web page, be sure to let me know :-)
Show messages: All  1-5  6-7
