¿how can I make a ramp in the shape of snail?
4069.1
The width of the ramp I want to make has 0.5m in the beginning and 4.5m at the top, the height es 3.4m. other thing is that the beginning is 15m frome the center to the out edges and the end is 11.8m from te center to de edges. I wish someone could help me.
4069.2 In reply to 4069.1
Hi diego, you'll probably want to use the Sweep command to build a shape like that.
Start by making the path curve using the Helix command, it's under Draw curve > More > Helix.
Click the "Tapered" option inside of the helix command to allow setting a different radius at the top and at the bottom of the helix.
Then after you have checked that "Tapered" option, you pick 2 points to define the central axis line of the helix, which will set the height from the base to the top - use "Distance constraint" to set the 2nd point to a specific distance if you want, by typing in the distance value that you want before doing that second pick.
Then after you have placed the axis line you will then pick a radius for the bottom and then a 2nd radius for the top, that will give you a path curve looking like this:
Then draw in a circle curve and select the circle to use as the profile curve, run the Construct > Sweep command, and pick that tapered helix as the path curve, to make something like this:
Hope this helps!
4069.3 In reply to 4069.2
Thanks Michael, it helps me a lot
