NX xform
All  1-5  6-13
4068.6 In reply to 4068.4
Hi Jamie,
> Although remaining editable after making a solid would
> be great I can see the trade off with complexity.
One of the tricky parts about that is that the surrounding faces may not have underlying surfaces that extend far enough to fill stuff in, in which case they need to be extended and doing that well is a difficult business.
> In fact any chance of a script to explode and untrim all?
Yup, try the attached UntrimAll plugin. To install it, unzip it and copy the 2 files into the \commands sub-folder that is underneath MoI 2.0's main installation folder.
That will then make a new command named UntrimAll available - to trigger it make a new shortcut key and put in UntrimAll as the command name.
That should then give you a combined explode and untrim of all exploded faces in one keystroke.
4068.7 In reply to 4068.6
Hi Michael
The UntrimAll plugin works perfectly. thankyou for taking the time to do it, a very happy customer here. Incidentally it is also useful for removing fillets. I also tested it untrimming an object from rhino to remove fillets.
One other thought and I have no idea how possible it is, when you explode and untrim you have the original surfaces so you can tweak with control points or move the entire surface but you have lost the associativity with the original curves that created it. So if it was a loft you cannot edit the loft curves and the surface update. Of course its not that difficult to recreate the surface if needed but it would be great if once exploded out of the solid the surfaces found the curves that made them so the remained editable.
thanks again
Jamie
4068.8 In reply to 4068.7
You're welcome Jamie, I hope it is useful!
> remained editable.
So unfortunately trying to make some kind of persistent deep linkage between objects like you're describing is not really something that's feasible to cook up with a script.
In the future I do want to work on making some deeper history functionality, but that will involve a lot of new core mechanisms and not just scripts.
The way that I would hope to get it working eventually would be that you could set up your curves, create surfaces from them, and then use boolean merge to make the solid part, but each of these steps would be remembered so you could then edit a curve and then those actions would all recalculate.
4068.9 In reply to 4068.8
Can you post a little image or a shema of the Scrip explode + untrim
- before / after -
4068.10 In reply to 4068.9
Hi Pilou, there's an image in Jamie's previous post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4068.4
The "UntrimAll" plugin will do a combination of Edit > Separate to break a solid into individual separate surfaces, and then also remove all trim curves from those surfaces so that you'll see the full underlying surfaces (this is the same as selecting all edges of those surfaces and pushing delete).
So if you have a solid like the object on the right-hand side of Jamie's post above, when you run UntrimAll you will get a result with all surfaces untrimmed like the result on the left-hand side of Jamie's image.
4068.11 In reply to 4068.10
THX !
4068.12 In reply to 4068.8
Hi Michael
I didn't expect that kind of linking would be possible short term. What you describe is exactly what I would like to see, I guess its a question of managing the flip side of that, like what happens when it goes wrong. Will it confuse people, but I am confident you will find an elegant solution and I look forward to seeing it develop.
thanks again
Jamie
4068.13 In reply to 4068.1
Thanks for the cadjunkies link! I just signed up and I'm looking at some of the freebie videos now.
Show messages: All  1-5  6-13
