Hi FiL,
> I don't see it in the export tool.
Ah, but it is there.... ;)
Notice in your screenshot, there is a scroll bar on the right side of the list, here:
If you scroll down (click here):
Then you'll find Illustrator .ai as the last item in the list.
Also you don't actually need to use that list if you instead type in the .ai file extension in your file name. If you type in a particular file extension, MoI will write to that file type and you can skip setting that dropdown in that case. You only have to use the dropdown if you don't type in any file extension.
