Rhino is ok for 2D - MoI to?
All  1-6  7-15
4056.7 In reply to 4056.4
Hi 2kemon,
> Looking further into the demo, just the little detail that
> you don't automatically orbit when in "top view" is a
> potential god-sent timesaver, if you plan to buy and use
> MoI in a future 2D workflow.
Yeah this is one of the benefits of having a multi-viewport type structure. Because MoI has a dedicated "Top" viewport that you can switch to, it makes it possible for MoI to treat that view somewhat differently than the 3D view and make it behave more like a 2D environment. The object frame that goes around the selected objects helps with this as well.
> Does an .ai export preserve the choice of line color?
No, not currently - the AI export right now is pretty basic. Colors were a new thing added in for MoI v2 and they haven't quite percolated down to all areas of the program yet.
Improving the AI export is on my target list for version 3 though.
Colors do get exported to the CAD formats like 3DM and IGES though, so if you use a CAD program to do the import they can come through that way.
4056.8 In reply to 4056.5
Hi eric,
> I am aware that MoI won't export to .dwg directly but do you
> know if there is a free or inexpensive program out there
> that would do the conversion?
One inexpensive option is ViaCAD, I think the ViaCAD 2D version (price = $40) is able to read both 3DM and IGES CAD data and can export to DWG.
http://www.punchcad.com/c-12-consumer-cad.aspx
There are also a variety of free 2D CAD programs out there like Draftsight and DoubleCAD XT but many of these are focused on kind of being AutoCAD clones and don't import a lot of formats other than ones that AutoCAD does as well.
4056.9 In reply to 4056.8
Hi Michael ...
Yes, ViaCad does look like a workable option.
It seems that MoI, ViaCad and possibly Draftsight would make a very inexpensive modeling and drafting combination.
Add one of the lesser expensive rendering programs and 3d PDF and one would have a pretty complete tool box.
I personally have a bunch of more expensive programs but am always on the lookout for workable solutions
for people getting started with low budgets.
And, if a few hundred dollars will produce professional results why spend thousands?
thanks for the information.
cheers,
eric
4056.10 In reply to 4056.9
Hi eric,
Yup, and maybe Simlab Composer would fit in well for those tasks, I think their "Rendering Edition" version handles both rendering and generation of 3D PDF files as well, and it's $149: http://www.simlab-soft.com/
4056.11 In reply to 4056.10
""""""""I think their "Rendering Edition" version handles both rendering and generation of 3D PDF files as well""""""""""
It's also the Luxon render engine... Which is basically hypershot/keyshot renders!
4056.12 In reply to 4056.11
Yes, the Sim Lab renderer is good and the 3d PDF is awesome ... a great way to present a project to a client.
The last house I designed I did a construction and framing detail plan with lots of 'layers' or 'styles' and the client could turn them on or off at will to better understand the construction process. Good stuff.
cheers,
eric
4056.13
I use Moi to make 2d stuff all the time, it's easier and faster at on many levels.
Object management with styles is faster than any other I know.
Some examples:
Click on text description to select all in this style, ctrl+click to subtract one style
Right-Click the Eye to isolate the style, Ctrl+click to lock.
Swipe to rapidly on the eyes to turn on or off a bunch of styles.
I use other programs to dimension.
There is a script to transfer curves to dxf:
http://kyticka.webzdarma.cz/3d/moi/converter/3dmCurves2DXF/3dmCurves2DXF.zip
Marc
4056.14
Hi, I agree with the ones that say MoI is great for 2d drawings! I have tried 2 methods for exporting MoI files to Autocad: 1. Export as SAT. This option doesnt let you export the styles. 2. Use the rhino dwg exporter, it does allow you to export styles!
4056.15
Yes, I use MoI for a lot of 2d work. It's my favourite drawing program, for 2d and 3d.
(I make art for my games in it)
Show messages: All  1-6  7-15
