Moving points on composit objects
4052.1
I'm a 3DS Max guy trying to get my feet wet with solid modeling.
Is it possible to change the shape of my model by moving the yellow edge in the image above? I understand that Show Points will turn on for simple shapes, but not for models like this. Can you help me understand why? Is there a way to move the selected edge? Or does everything have to be done before my objects are joined together and filleted?
4052.2 In reply to 4052.1
No you can't (no kill, no move) just separate all the volumes but not sure that help you!
Just make CTRL+Z and remake your Fillet with another Angle
Or make any Boolean operation with some volumes made
with this yellow curve (copy - scale etc) as curve generator + existing curves ;)
EDITED: 16 Feb 2011 by PILOU
4052.3 In reply to 4052.2
Is this a limitation of MOI or Solid Modeling in general?
Are there solid modelers that are more "elastic"?
thank you
4052.4 In reply to 4052.3
Most parametric or direct modeling apps will give you the choice to edit features like fillets later on...http://www.youtube.com/watch?v=DH8DFtF-m8k http://www.youtube.com/watch?v=pqE737atPnY
fusion is a good place to start since you use 3ds max (DWG support ;) you can download for free from the labs site, just log in with your max account. From what I heard is gonna be free for Autocad, Inventor users...
BUT be aware is not a friendly as MoI :)
4052.5 In reply to 4052.4
Fusion looks interesting.
But as for MOI, if my boss came to me and said, "This looks good, but move that edge over an inch." What would I do? Would I have to start over?
I'm not criticizing MOI. I'm just trying to get a feel for the work flow of my first solid modeling program.
I read in the FAQ how moving a point would tear faces away. What I don't understand is why the program can't just re-evaluate the surface based on the new location of the edge.
thanks.
4052.6 In reply to 4052.5
Hi Shawn,
Well, it depends on the situation - if the piece you have to change is pretty simple you can just build it over.
But you can also re-use existing surfaces as well - you can take some set of surfaces and break them off of the main object by using Edit > Separate, then move them over, remove the trim curves from the old areas, and then trim a new hole in the new spot and then join the pieces back together again.
There's an object repair tutorial here that covers that kind of low level surface trimming/untrimming and joining workflow here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
But if you think that's going to be a common thing to make modifications you may want to use one of the more regular solid modeling systems like SolidWorks / SolidEdge / etc... instead of MoI because those programs have systems in place for maintaining the history of how the object was constructed so you can go back and make modifications and have the model update.
In the future I do want to try to have some deeper history functions in MoI as well, but the overall focus in MoI right now is more on making it quick and easy to draw things initially. One of the negative side effects of those other solid modeling systems is that they're just more complex and tend to have somewhat more steps that you have to go through to create things. But if you need to make changes later on they work really well for that.
> the edge.
The problem is that unlike a polygon model, the edges do not define the surface at all - there is already a separate surface underneath the edges.
Here's an example - here I have a trimmed plane surface:
If I turn on control points for the surface, you can see that the underlying surface is a simple plane with just 4 corner points like this:
If you could edit edges directly, say you wanted to go in and pull this vertex upwards in z:
How then would the plane surface adapt to go through those deformed edges? There isn't any way to just move the surface's 4 control points to make the surface go through that modified edge. That's why you can't edit just any edge - if it's a trim curve it's just marking different areas of the surface as holes or solid areas, it's not defining the shape of the surface.
This is one of the things that's very different between polygon modeling and NURBS modeling - in polygon modeling the actual surface shape is completely defined by the edges, so moving the edges implicitly moves the surface as well, they are one and the same. In a NURBS model after you have done some booleans, you have trim curves which are a separate thing from the surface, there is a separate underlying surface that makes the surface shape and the trim curves are just markers on it.
But this system of an "underlying surface" and "trim curves" is basically what makes boolean operations work so much better with NURBS than with polygons because when you do a boolean with NURBS the underlying surface actually stays exactly the same as before, just new trim curves are calculated on it. Booleans with a poly modeler on the other hand actually dice the polygon surface up into smaller and smaller surface fragments with each boolean.
4052.7 In reply to 4052.6
I think I'm understanding. Thanks!
