STEP not making true cylinders?
4041.1
Michael,
I modeled some components and exported using (Save as) to STEP. I then imported the file into Pro/ENGINEER which comes in fine but with errors (Geom Check, which could mean sliver edges).
I then tried to add datum axis to the cylindrical parts so that I could then assemble the parts in Pro/ENGINEER assemblies. However, Pro/ENGINEER will not recognize cylinders exported via STEP, because what usually will happen is I can select the curved wall of a cylinder to then have an axis run through the center.
I even tried modeling a cylinder with the same exercise with the same results.
Now, what's really interesting is I did this on an older version of Pro/ENGINEER (Wildfire 2) but importing to Wildfire 5 seemed to have the expected results.
This might serve as a warning for now, because I'm kinda scratching my head as to why such a basic shape has 2 results. But what could be an issue is anyone else using different CAD systems expecting standard results.
- Jason
http://www.jasedesign.com http://www.cgpipeline.com
4041.2 In reply to 4041.1
Hi Jason,
> sliver edges).
Well, it's certainly possible to create small edges in MoI, in any number of ways - for example if you boolean together 2 objects that are slightly misaligned that will usually create some small sized edges in the result.
Is it possible for you to send me the particular file that Pro/E is complaining about so I could take a look at it?
re: cylinders - when MoI writes out surfaces to the STEP file, it just writes them as generic "NURBS surface" entites (which do have an exact cylindrical shape though if it was a cylinder), and not as a special cylinder entity.
Often times if a program needs to do something special with particular kinds of primitive objects, they may detect if the imported NURBS surface has the exact shape of an analytic primitive when they read the file - it sounds like the newer version that you were importing into has that analytic detection in it, and the older version does not have analytic detection. Does that help explain what you are seeing?
4041.3
Just some info, thought it might help, MoI cylinder imported into NX6 as STEP.
Surface type: (non parametric) Cylindrical
