Hi Armin, also I see now that there is a bug in that setting in the Options dialog, where if you type in filename in the text field there (to the left of the "..."), what you typed in there does not stick if you close the dialog directly after that.
If you switch to a different category (like to "Grid" or "Shortcut keys", etc...) before closing the dialog that will actually make a directly typed in template file setting to stick and so you can use that method to enter in a value without a path using the options dialog.
