Option request for the sweep tool.
All  1-2  3-4
4029.3 In reply to 4029.2
In the file attached there is the results of the sweep that I always get. However, I want the edge of the profile to follow the path not the center point of the profile. That way my finished sweep is 12" x 12" with the profile on the edge.
I have tried to put the profile on the path and I either get no results or a flattened 2D result.
Thanks for your help.
4029.4 In reply to 4029.3
Hi Drakonsden,
When you put the profile on the path, it will be swept directly from its current location so that means that you also have to rotate it into the orientation that you want.
See the attached file for an example that should give you the proper result.
I understand now what you mean by picking the point though - you want to be able to pick the origin point for where the profile is located in relation to the rail in "auto place" mode. That is on my list of things to add to Sweep in the future.
For now though to get the result you were looking for you need to position things as in the attached file.
Show messages: All  1-2  3-4
