Repair Machine Part to Casting Part
All  1-9  10-15
4017.10 In reply to 4017.7
Hi Michael T.
>Do you have access to a system with direct modeling capabilities such as delete surface etc.?
In MoI I can delete machine area just by hitting "delete". But this not easy task to bring the trim surfaces to the initial shape. Do you have experience on this area you can share...? Not only use MoI, if you have another software that can help it will be good... At least I can follow the trick.
Thanks... ;)
4017.12 In reply to 4017.11
Looks like Geomagic is use to convert mesh data from scanner to nurbs surfaces.
Thanks...
4017.13
Hi Anis,
For the time I had it's a little rough but I think if it's going to machined later it should be good enough.
Only had time for one side, maybe it will translate to the other side, didn't check.
4017.14 In reply to 4017.12
You can import any 3Dfiles not only from a scanner ;)
POLYGON IMPORT/EXPORT
3DS OBJ
DXF PLY
IGS STL
LWO VRML
NAS WRP
CAD IMPORT/EXPORT
IGES
STEP 203/214
Neutral
VDA
Pro/E PRT
Parasolid .x_t* and .x_b*
SAT
http://www.youtube.com/watch?v=Kbnbea3Hr9E reverse ingineering
http://www.youtube.com/watch?v=0gJThuVyMSQ hole filling
etc...
EDITED: 3 Feb 2011 by PILOU
4017.15 In reply to 4017.10
Hi Anis,
I do use ViaCAD at home as well as MoI. It does have direct modeling features. It is inexpensive. Sometines (as with all direct modeling softwares) can be tempermental :-) No guarentees.
I have used it to remove fillets to alter geometry and then replace the fillets.
You can PM me if you like to see if I can do something with it.
Let me know.
Michael T.
Show messages: All  1-9  10-15
