Insets Along Curved/Tapered Surface
All  1-6  7-8
4010.7 In reply to 4010.5
Hi Skwerm, also instead of rotating the domes, an easier solution would be to just move the cutting objects just a little bit outwards before booleaning them so that there won't be that little edge part left towards the inside.
If you move it about 0.03 units outwards it would do the trick.
4010.8 In reply to 4010.6
Hi Skwerm, I've attached an example here - this one should now fillet more easily after it is booleaned.
The pieces are just very slightly positioned further out from your previous one.
Show messages: All  1-6  7-8
