Insets Along Curved/Tapered Surface
4010.1
Hello, all! I'm a poly and CAD modeling veteran trying to come to grips with the elegant world of nurbs modeling.
I'm trying to model a street light pole that has a curved/tapered base imprinted with vertical grooves. I've attached a PDF showing the pole and base I'm trying to model as well as the meager beginnings of the base. As you can see in the 3DM, I've projected the outer shape of the inset groove to the surface of the base, but now I'm stuck with what to do next. I'm beginning to think I'm on the wrong track altogether.
If the base was a cylinder and wasn't curved/tapered I'd just make a cylinder with hemispherical end caps and boolean that out of the base. But the curved/tapered nature of the base's surface won't allow this workflow. So here I am; stuck.
I will appreciate any and all help with figuring out how best to do this.
Thanks!
4010.2 In reply to 4010.1
Hi Skwerm, you're going in the right direction. Often times for making a little inset piece it can be easiest to actually cut your main surface to get a smaller surface fragment, and then either extrude or shell that smaller surface fragment into the inset piece. That way you generate an inset piece where the inside part follows along the same contour as the outside surface.
See this previous post for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
Also check out here for some ideas on cutting grooves into things:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3859.2
I'll try to show you some steps with your actual model in a bit.
4010.3 In reply to 4010.2
Another way of doing it is to cap the cone shaped part with planar surfaces and join to make a solid. Then use the projected curve to trim the curved surface, keeping both pieces. You can then extrude the cut piece of the surface to make another solid. If you fillet this it will make a cutter. Go back to the curved surface and delete the original trim edges. That will turn it back to a solid. You can then array the cutter in a circular array and use it to boolean difference the cone shape and create the indents.
4010.4 In reply to 4010.1
Hi Skwerm, so the steps go something like this:
You can start out with just the original 2D curve and your surface like so:
Select the surface and do a Ctrl+C to copy it to the clipboard, because you're going to want a duplicate of it in a minute since we will be cutting it up.
Then select the surface and run the Edit > Trim command - Trim has projection of planar cutting curves built into it so it is not necessary to do a separate projection step beforehand.
Then inside the Trim command, select your planar curve as the cutting object, and then pick these 2 pieces as the pieces to discard:
Then when you right-click or push the Done button to finish the Trim command it will leave you with this surface piece here:
Actually this would also be a good time to either delete or hide the original 2D cutting curve to get it out of the way. I happened to do that a little bit later in my screenshots here, but often times it can be good to get things that are in the middle of your model like that out of the way so that you won't accidentally pick them when doing other steps.
So another note is that you usually want to use the Trim command to cut an open surface into surface fragments. The boolean commands also cut up objects but the booleans are more oriented towards working on solids that make a closed volume. The different variants of boolean (like union, difference, etc...) decide which pieces to discard based on which volume they are in. When you don't have any volumes and only have surfaces, you use the Trim command instead which makes all the cut up fragments available and then you pick which pieces you want to discard.
So anyway, now you want to take this surface fragment and make it into a cutting object with some depth to it - you can do that by selecting it and running the Construct > Extrude command on it. You will need to use the "Set Dir" option in Extrude to tell it which direction to extrude in - pick 2 points to define the direction and then a 3rd point to define the extrusion distance.
That will generate a kind of plug solid object like this:
Now use the Transform > Array > Circular command to duplicate it into a radial pattern:
Now do Ctrl+V to bring back the original full revolve surface before it was trimmed:
If you forgot to copy it to the clipboard earlier, then do some undos until you get back to it, then select it and Ctrl+C to copy it, and then use Redo to get back again. Sometimes this undo + copy + redo sequence can be a quick way to bring back a duplicate of some original piece that you have just modified recently.
So that will look like this now:
Now to do a boolean you need to solidify the revolve surface - you can do that by selecting it and running the Construct > Planar command on it - that will build some planar surfaces at the top and bottom and join them to the revolve to make it a solid object which will then work well with booleans:
Then select the center revolve piece and run Construct > Boolean > Difference and select those plugs as the cutting objects. This is also where you want to make sure not to select the 2D curve that was used to trim with earlier, because if you did select that it would also be used as a cutting object and cut a hole all the way through the revolve:
But one thing that was kind of odd was that the boolean was taking a much much longer time than normal to complete for this case, something seemed to be confusing it, possibly something to do with the directly overlapping pieces. It went back to a more normal quick calculation time when I ran the "ShrinkTrimmedSrf" command on the cutting pieces:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#shrinktrimmedsrf
So normally when you do a trim, the full original surface is actually there as part of the cut piece - that's how trimmed NURBS surfaces work, where there is an "underlying surface" that then has areas of it marked as inactive spots by trim curves on it. The ShinkTrimmedSrf command shrinks down the underlying surfaces and throws away parts of the surface that are larger than the current active piece of it.
Normally it should not be necessary to use it, but in this case it seems to clear up some confusion that the booleans are having with resolving the coincident surfaces.
Anyway, hope this helps!
4010.5
First, thanks for all the help!
I'd accomplished something very similar to your suggestion shortly after posting the question. We're getting close!
However, as I'd stated in the original post, the grooves are not sharp extrusions inward. Instead they are kind of half "hot-dog" shapes removed from the base mesh. I'd said something about being able to create a cylinder with hemispherical end caps and removing them with a boolean operation.
So the current state of affairs is attached to this post. I drew a vertical line, projected it onto the curved surface, and then used the resulting curve as a sweep curve. I then capped those ends with spheres and bool-added them together and removed them from the base.
So far so good.
However, I can't add fillets to the edges of the removed areas. The boolean removals worked fine (I think) but I get no result when I select the resulting edges and try to apply a fillet of any radius.
Again, many many thanks for the help. If I can get filleted edges I'll have the solution to the problem.
Cheers!
4010.6 In reply to 4010.5
Hi Skwerm, sorry I had missed that part about the indents being capsule-like.
So yeah the basic process will still be similar, you've got to try and model the capsule parts as some kind of solid object first and then use that to cut the main body with a boolean.
You're having some fillet troubles in this case because of a little tiny edge in your booleaned result here (looking here from below upwards):
Zooming in on that area you can see this little tiny edge fragment, shown selected here:
That little edge corresponds to the seam edge of the dome part of your capsule object:
That's going to be a problem for filleting, because the filleter is not able to totally consume an edge like that away, the fillet is going to be limited in size up to the point where it hits the end of that little edge, which is only a very small distance.
So you're going to want to get those dome pieces rotated around a bit so that when they leave their imprint they won't have such a small bit of edge left in the surviving piece.
4010.7 In reply to 4010.5
Hi Skwerm, also instead of rotating the domes, an easier solution would be to just move the cutting objects just a little bit outwards before booleaning them so that there won't be that little edge part left towards the inside.
If you move it about 0.03 units outwards it would do the trick.
4010.8 In reply to 4010.6
Hi Skwerm, I've attached an example here - this one should now fillet more easily after it is booleaned.
The pieces are just very slightly positioned further out from your previous one.
