Adding "inset" detailing
All  1  2-4
3985.2 In reply to 3985.1
Hi Jim, you'll need to create a solid that is pushing downwards a ways into your object and then use that solid as the cutting object in boolean difference to cut it away from the main piece.
But since you want a piece that follows the same general shape as the original outer surface, you'll probably want to build that cutting object solid by trimming out a small portion of that original outer surface and then probably using Extrude to extrude that smaller surface fragment into the cutting object.
See this previous post for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
Also check out here for some ideas on cutting grooves into things:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3859.2
3985.3 In reply to 3985.2
Thanks! I'll check those out.
By the way, the more I use Moi, the more I love the simple to use UI. It's hands down the most graceful UI I've ever used, I don't know specifically what it is, but you've really pared things down to their essentials, yet it seems like it's still a really powerful tool! I wish some of the other tools would follow suit (Blender, this especially means you!).
3985.4 In reply to 3985.3
Thanks Jim, I'm glad that you are liking MoI's UI!
Show messages: All  1  2-4
