Boolean difference oddity
All  1-3  4-7
3973.4 In reply to 3973.2
Hi Steve,
> There is a Flip command but I can't make it work.
The flip command doesn't do anything on a closed solid, because there is a mechanism that performs intersection tests on solids to determine the outside.
But that mechanism can get confused if there are self-intersecting surfaces in the model, which there was in this case - the side wall portion of the green piece is a surface with a bunch of control points in it and it folds back over top of itself near the tip.
If that area is repaired to not have a self intersecting surface (see attachment above), then things will work properly with it.
3973.5
Heya guys, thanks for the investigation!
I chose to cut this Gordian knot by remaking the base ship using a looser loft instead of normal loft. Evidently that must have cured the wacky fold that you pointed out.
3973.6 In reply to 3973.5
Hey Yenmonger,
I looked at making this shape a little better with a "rail revolve".. Here is the result.. The revolve curve I had adjusted the 2 endpoints to be tangent, as opposed to the little wiggle at the end. I also made all curves planar.
3973.7
Thank you, sir.
Show messages: All  1-3  4-7
