newby - weird radii - how to create for cnc cutting
 1-4  5-24  25-27
3970.25 In reply to 3970.24
Hi Gary.
I use it for all sorts of 2D/3D cnc work.
I've made quite a few moulds from stl files and one of the nice things about CamBam that I find very convenient, is that it's able to cut one from the actual solid model itself. So no messing about, by having to subtract the positive to get a negative.
In case you didn't you know, it has 40 trial sessions (over any length of time), so you could grab a copy and have a play at your leasure.
Like MoI, it's also got a friendly, well behaved forum.
Martin.
3970.26 In reply to 3970.23
Gary,
I like my Hybrid. It took about a month to build but at the end of the project I knew exactly what each part did and where to source a spare. It also gave me the confidence to do some modifications of my own. I drew up a new Z in MOI and cut it using my original Hybrid. It was my first project in aluminum and thanks to MOI everything fit perfectly. Re: downloading files into Cut 3D, it's a snap. When in MOI use the file save as command and select either stl or obj then import the file into Cut 3D. Unfortunately I seem to remember that the demo wasn't fully functional. I think you can only run files included in the demo.
Bob
3970.27 In reply to 3970.26
BobK,
Thanks for the info on Cut3D. I really appreciate hearing from someone that is actually using a package.
I think that Vectric's VcarvePro is the best package that I came across. I had tried or bought and abandoned several packages before theirs and it is amazing how easy to use it is and how powerful it is for a 2 and a 2 1/2 dimension package. Their photo carving package does amazing things in wood as well!
I do find that the Cut3D package seems a little bare. I will probably buy it though as I know for a fact that it will work because it's from Vectric.
Thanks again,
Gary
Show messages:  1-4  5-24  25-27
